G
| GBOOM | No. 0 very light yellow filter; screw-on type L | ca.1939 | - |
| GBWOO | No. 1 light yellow filter; screw-on type L | ca.1939 | - |
| GCHEO | Kodachrome flash filter; screw-on type L | ca.1949-19?? | NY item |
| GCHEOMI | Kodachrome flash filter; screw-on type E39 | ca.1949-19?? | NY item |
| GCOOL | No. 2 yellow filter; screw-on type L | ca.1939 | - |
| GCSKYMI | Kodachrome skylight filter; screw-on type L | ca.1949-1950's | NY item |
| GCYOD | Panchromatic no. 2 green filter; screw-on type L | ca.1939 | - |
| GCYOO | Panchromatic no. 1 green filter; screw-on type L | ca.1939 | - |
| GDOOK | Orange filter; screw-on type L | ca.1939 | - |
| GECOO | Infra-red no. 1 light filter; screw-on type L | ca.1939 | - |
| GFEOO | Infra-red no. 2 medium filter; screw-on type L | ca.1939 | - |
| GFOOH | Infra-red no. 3 dark filter; screw-on type L | ca.1939 | - |
| GHIOO | UVa filter; screw-on type L | ca.1939 | - |
| GHOOF | Graduated yellow filter; screw-on type L | ca.1939 | - |
| GIIBR | Microphotography 18 inch cable release for MIKAS with set screw mount | 1939-19?? | - |
| GIIEF | Microphotography 1/3x conical extension tube for MIKAS with screw-mount | 1939-19?? | - |
| GIIEF-M | Microphotography 1/3x conical extension tube for MIKAS with M-mount | 1939-19?? | - |
| GIIFT | Microphotography 18 inch cable release for MIKAS with screw-mount | 1939-19?? | - |
| GIIMW | Microphotography 1/2x conical extension tube for MIKAS with screw-mount | 1939-19?? | - |
| GIIMW-M | Microphotography 1/2x conical extension tube for MIKAS with M-mount | 1956-19?? | - |
| GIINK | Microphotography 1x conical extension tube for MIKAS with screw-mount | 1939-19?? | - |
| GIIOX | Single exposure housing without shutter | 1939-1940's | NY item |
| GILOO | Graduated green filter; screw-on type L | ca.1939 | - |
| GMOOA | Leica IIIg with Summarit f= 5 cm 1:1.5 SOOIA | 1957-1970 | - |
| GOOCE | Leica IIIg with ELMAR | 1957-1970 | - |
| GOOEF | Leica IIIg body | 1957-1970 | - |
| GOOEL | Leica IIIg with Elmar f= 5 cm 1:2.8 (ELMOO) | 1957-1970 | - |
| GOOMI | Leica IIIg with Summicron (I) f= 5 cm 1:2 (SOOIC) | 1957-1970 | - |
| GOORM | Copy stand arm for 1 1/4 inch column with tape measure for rotating stage OORES or 250 stage GRBOO | 1938-ca.1950 | - |
| GOOSZ | Complete copy stand with GOOZQ arm for 1 1/4 inch column with tape measure for rotating stage OORES either direct or with ball and socket KAGOON head | 1938-ca.1950 | - |
| GOOZQ | Copy stand arm for 1 1/4 inch column with tape measure for rotating stage OORES either direct or with ball and socket KAGOON head | 1938-1950 | - |
| GRBOO | Sliding stage for Leica 250 (models DD, FF & GG) | 1935-ca.1950 | - |
| GROOW | Basic copy stand with spring mounted base plate | 19??-19?? | - |
| GVKOO | 30 mm extension ring G for ZWTOO-HESUM | 19??-19?? | - |
