Elmar (II) f= 5 cm 1:3.5
  • Leica Order No. - ELMAR LLC - 113
  • Production era - 1946-1959
  • Variants - Red scale - 1951-1959
  • Lens mount - Leica Screw-thread
  • Number of lenses /groups - 4 /3
  • F stop range - f/3.5 > f/22
  • Smallest object field -
  • Diaphragm setting /type -
  • Filter type - A36
  • Accessories -
  • Materials - Chrome plated brass
  • Weight - 125 g /4.41 oz
  • Inscription - Leitz Elmar f=5cm 1:3,5
  • Forum discussion
595000 596000 Elmar 5 cm 1:35 1945 1001
597001 600000 Elmar 5 cm 1:35 1945 3000
601001 603000 Elmar 5 cm 1:35 1946 2000
609001 610000 Elmar 5 cm 1:35 1946 1000
612001 615000 Elmar 5 cm 1:35 1946 3000
630001 633000 Elmar 5 cm 1:35 1946 3000
633101 635000 Elmar 5 cm 1:35 1947 1900
638001 643000 Elmar 5 cm 1:35 1947 5000
647001 652000 Elmar 5 cm 1:35 1948 5000
670001 675000 Elmar 5 cm 1:35 1948 5000
688001 693000 Elmar 5 cm 1:35 1949 5000
707001 712000 Elmar 5 cm 1:35 1949 5000
727001 732000 Elmar 5 cm 1:35 1949 5000
741001 750000 Elmar 5 cm 1:35 1949 9000
769001 775000 Elmar 5 cm 1:35 1950 6000
790020 790036 Elmar 5 cm 1:35 1950 17
802001 807000 Elmar 5 cm 1:35 1950 5000
826001 836000 Elmar 5 cm 1:35 1950 10000
866001 872000 Elmar 5 cm 1:35 1951 6000
893001 898000 Elmar 5 cm 1:35 1951 5000
904001 910000 Elmar 5 cm 1:35 1951 6000
941001 950000 Elmar 5 cm 1:35 1951 9000
955001 956000 Elmar 5 cm 1:35 1952 1000
957501 958000 Elmar 5 cm 1:35 1952 500
987151 990000 Elmar 5 cm 1:35 1952 2850
998001 999000 Elmar 5 cm 1:35 1952 1000
1000001 1004000 Elmar 5 cm 1:35 1952 4000
1010201 1015000 Elmar 5 cm 1:35 1952 4800
1045001 1050000 Elmar 5 cm 1:35 1952 5000
1063001 1072000 Elmar 5 cm 1:35 1953 9000
1086001 1091000 Elmar 5 cm 1:35 1953 5000
1100001 1103000 Elmar 5 cm 1:35 1953 3000
1121501 1124000 Elmar 5 cm 1:35 1953 2500
1140016 1143000 Elmar 5 cm 1:35 1954 2985
1148222 1149100 Elmar 5 cm 1:35 1954 879
1163001 1166000 Elmar 5 cm 1:35 1954 3000
1183501 1187000 Elmar 5 cm 1:35 1954 3500
1198001 1203000 Elmar 5 cm 1:35 1954 5000
1242001 1245000 Elmar 5 cm 1:35 1955 3000
1294001 1297000 Elmar 5 cm 1:35 1955 3000
1320001 1325000 Elmar 5 cm 1:35 1955 5000
1333001 1337000 Elmar 5 cm 1:35 1956 4000
1340001 1345000 Elmar 5 cm 1:35 1956 5000
1372001 1375000 Elmar 5 cm 1:35 1956 3000
1426001 1429000 Elmar 5 cm 1:35 1956 3000
1455001 1458000 Elmar 5 cm 1:35 1956 3000
TOTAL ASSIGNED SERIAL NUMBERS 1946-1956 1
Note: Some of the numbers between 1945 and 1950 should be assigned to Elmar (I) f= 5 cm 1:3.5 and some of the numbers between 1950 and 1956 should be assigned to Elmar (III) f= 5 cm 1:3.5
