Summicron (I) f= 9 cm 1:2
- Leica Order No. - SOOZI, SEOOM 11123 11133 LLC - 174
- Production era - 1957-1962, 490 screw lens, 4430 bayonet lens < 13,800 lenses
- Variants - All black, all chrome, and black and chrome versions; preset ring with f/16 or f/22 minimum aperture
- F stop range - f/2 > f/22
- Diaphragm setting /type -
- Filter type - E48
- Accessories - Hood: HMOOD
- Materials -
- Dimensions length x diameter - 110 x 66 mm / 4.33 x 2.60 in
- Weight - 660 g /1.46 lb
- Inscription - LEITZ CANADA 165XXXX SUMMICRON 1:2/90; Ernst Leitz Canada Ltd. Midland Summicron f = 9cm 1:2 Nr. 158xxxx
- Designer - Walter Mandler
Summicron (I) f= 9 cm 1:2 Serial Numbers
| 1119001 | 1119200 | Summicron f= 9 cm 1:2 | 1953 | 200 |
| 1477001 | 1477100 | Summicron f= 9 cm 1:2 | 1957 | 100 |
| 1580001 | 1581000 | Summicron f= 9 cm 1:2 | 1958 | 1000 |
| 1651001 | 1652000 | Summicron f= 9 cm 1:2 | 1959 | 1000 |
| 1652451 | 1653450 | Summicron f= 9 cm 1:2 | 1959 | 1000 |
| 1680001 | 1682000 | Summicron f= 9 cm 1:2 | 1959 | 2000 |
| 1740001 | 1743500 | Summicron f= 9 cm 1:2 | 1960 | 3500 |
| 1743501 | 1746500 | Summicron f= 9 cm 1:2 | 1960 | 3000 |
| 1817001 | 1819000 | Summicron f= 9 cm 1:2 | 1960 | 2000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1953-1960 | 13,800 |
