28mm f/2.8 Elmarit I
- Leica Order No. - 11 801 LLC - 144
- Production era - 1965-1969
- Variants - Yellow /white scale; red /white scale; Wetzlar and ELC versions have different optical designs, Wetzlar has a deep intruding lens and can't be used with built-in meter, Canada can be used on M5 and all other leicas with built-in meter and has the same optical formular as Elmarit II.
- Number of lenses /groups - 8 /6
- F stop range - f/2.8 > f/22
- Closest focusing distance - 0.7 m /2.30 ft (M3 1 m)
- Smallest object field - 533 x 800 mm
- Diaphragm setting /type -
- Filter type - Series 7, E48
- Accessories - Viewfinder: SLOOZ; Hood: 12501
- Materials -
- Dimensions length x diameter - 56 x 52.5 mm / 2.20 x 2.07 in
- Weight - 225 g /7.94 oz
- Inscription - LEITZ WETZLAR (or CANADA) ELMARIT 1:2.8/28 2XXXXXX
- Designer - Otto Zimmermann, Heinz Marquandt, Herman Desch and Eugen Hermanni
28mm f/2.8 Elmarit I Serial Numbers
| 2061501 | 2063500 | 28mm f/2.8 Elmarit | 1964 | 2000 |
| 2196901 | 2198100 | 28mm f/2.8 Elmarit | 1966 | 1200 |
| 2314801 | 2316000 | 28mm f/2.8 Elmarit | 1969 | 1200 |
| 2459501 | 2460500 | 28mm f/2.8 Elmarit | 1970 | 1000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1964-1970 | 5,400 |
Lens superseded by 28mm f/2.8 Elmarit II
