Summilux (I) f= 5 cm 1:1.4
Revision as of 19:25, 25 March 2010 by Admin (talk | contribs) (→Summilux (I) f= 5 cm 1:1.4 Serial Numbers)
- Leica Order No. - SOWGE 11014, SOOME 11114, 11621 LLC - 126
- Production era - 1959-1961 < 21,600 lenses (584 screw-mount lenses, per Schouten)
- Variants - Black and clear anodized, knurled and cylindrical versions
- F stop range - f/1.4-f/16
- Smallest object field - 410 x 620 mm
- Diaphragm setting /type -
- Filter type - E43
- Accessories - Hood: XOOIM 12521 used with OROBA or ORNIO cap (see Forum discussion [1] below}
- Materials - Lacquer on chrome plated brass
- Dimensions length x diameter - 52 x 53 mm / 2.05 x 2.09 in
- Weight - 320 g /11.29 oz screw; 360 g /12.70 oz bayonet
- Inscription - LEICA SUMMILUX 1:1.4/50 E46 388XXXX
- Designer - Erich Wagner
Serial numbers compiled from Puts Pocket Pod.* At least one in this batch is a Summaron 1:2.8/35mm per Westlicht
| 1640601 | 1642000 | Summilux f= 5 cm 1:1.4 (screw-mount) | 1958 | 1400 |
| 1644001 | 1645000 | Summilux f= 5 cm 1:1.4 | 1958 | 1000 |
| 1660001 | 1662000 | *Summilux f= 5 cm 1:1.4 | 1959 | 2000 |
| 1688001 | 1689500 | Summilux f= 5 cm 1:1.4 | 1959 | 1500 |
| 1690801 | 1691700 | Summilux f= 5 cm 1:1.4 (screw-mount) | 1959 | 900 |
| 1701501 | 1704000 | Summilux f= 5 cm 1:1.4 | 1959 | 2500 |
| 1730001 | 1731100 | Summilux f= 5 cm 1:1.4 | 1960 | 1100 |
| 1757001 | 1760000 | Summilux f= 5 cm 1:1.4 | 1960 | 3000 |
| 1765001 | 1766200 | Summilux f= 5 cm 1:1.4 | 1960 | 1200 |
| 1777001 | 1780000 | Summilux f= 5 cm 1:1.4 | 1960 | 3000 |
| 1788001 | 1790000 | Summilux f= 5 cm 1:1.4 | 1960 | 2000 |
| 1844001 | 1846000 | Summilux f= 5 cm 1:1.4 (screw-mount) | 1961 | 2000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1958-1961 | 21,600 |
