Elmar (II) f= 5 cm 1:3.5
- Leica Order No. - ELMAR LLC - 113
- Production era - 1946-1959
- Variants - Black scale (1946-1950), Red scale (1951-1959)
- F stop range - f/3.5-f/22
- Smallest object field -
- Diaphragm setting /type -
- Filter type - A36
- Accessories -
- Weight - 125 g /4.41 oz
- Inscription - Leitz Elmar f=5cm 1:3,5
Serial numbers compiled from Puts Pocket PodNote: Some of the numbers between 1945 and 1950 should be assigned to Elmar (I) f= 5 cm 1:3.5 and some of the numbers between 1950 and 1956 should be assigned to Elmar (III) f= 5 cm 1:3.5
| 595000 | 596000 | Elmar 5 cm 1:35 | 1945 | 1001 |
| 597001 | 600000 | Elmar 5 cm 1:35 | 1945 | 3000 |
| 601001 | 603000 | Elmar 5 cm 1:35 | 1946 | 2000 |
| 609001 | 610000 | Elmar 5 cm 1:35 | 1946 | 1000 |
| 612001 | 615000 | Elmar 5 cm 1:35 | 1946 | 3000 |
| 630001 | 633000 | Elmar 5 cm 1:35 | 1946 | 3000 |
| 633101 | 635000 | Elmar 5 cm 1:35 | 1947 | 1900 |
| 638001 | 643000 | Elmar 5 cm 1:35 | 1947 | 5000 |
| 647001 | 652000 | Elmar 5 cm 1:35 | 1948 | 5000 |
| 670001 | 675000 | Elmar 5 cm 1:35 | 1948 | 5000 |
| 688001 | 693000 | Elmar 5 cm 1:35 | 1949 | 5000 |
| 707001 | 712000 | Elmar 5 cm 1:35 | 1949 | 5000 |
| 727001 | 732000 | Elmar 5 cm 1:35 | 1949 | 5000 |
| 741001 | 750000 | Elmar 5 cm 1:35 | 1949 | 9000 |
| 769001 | 775000 | Elmar 5 cm 1:35 | 1950 | 6000 |
| 790020 | 790036 | Elmar 5 cm 1:35 | 1950 | 17 |
| 802001 | 807000 | Elmar 5 cm 1:35 | 1950 | 5000 |
| 826001 | 836000 | Elmar 5 cm 1:35 | 1950 | 10000 |
| 866001 | 872000 | Elmar 5 cm 1:35 | 1951 | 6000 |
| 893001 | 898000 | Elmar 5 cm 1:35 | 1951 | 5000 |
| 904001 | 910000 | Elmar 5 cm 1:35 (BS) | 1951 | 6000 |
| 941001 | 950000 | Elmar 5 cm 1:35 | 1951 | 9000 |
| 955001 | 956000 | Elmar 5 cm 1:35 | 1952 | 1000 |
| 957501 | 958000 | Elmar 5 cm 1:35 | 1952 | 500 |
| 987151 | 990000 | Elmar 5 cm 1:35 | 1952 | 2850 |
| 998001 | 999000 | Elmar 5 cm 1:35 | 1952 | 1000 |
| 1000001 | 1004000 | Elmar 5 cm 1:35 | 1952 | 4000 |
| 1010201 | 1015000 | Elmar 5 cm 1:35 | 1952 | 4800 |
| 1045001 | 1050000 | Elmar 5 cm 1:35 | 1952 | 5000 |
| 1063001 | 1072000 | Elmar 5 cm 1:35 (RS) | 1953 | 9000 |
| 1086001 | 1091000 | Elmar 5 cm 1:35 | 1953 | 5000 |
| 1100001 | 1103000 | Elmar 5 cm 1:35 (RS) | 1953 | 3000 |
| 1121501 | 1124000 | Elmar 5 cm 1:35 | 1953 | 2500 |
| 1140016 | 1143000 | Elmar 5 cm 1:35 | 1954 | 2985 |
| 1148222 | 1149100 | Elmar 5 cm 1:35 | 1954 | 879 |
| 1163001 | 1166000 | Elmar 5 cm 1:35 | 1954 | 3000 |
| 1183501 | 1187000 | Elmar 5 cm 1:35 | 1954 | 3500 |
| 1198001 | 1203000 | Elmar 5 cm 1:35 | 1954 | 5000 |
| 1242001 | 1245000 | Elmar 5 cm 1:35 | 1955 | 3000 |
| 1294001 | 1297000 | Elmar 5 cm 1:35 | 1955 | 3000 |
| 1320001 | 1325000 | Elmar 5 cm 1:35 | 1955 | 5000 |
| 1333001 | 1337000 | Elmar 5 cm 1:35 | 1956 | 4000 |
| 1340001 | 1345000 | Elmar 5 cm 1:35 | 1956 | 5000 |
| 1372001 | 1375000 | Elmar 5 cm 1:35 | 1956 | 3000 |
| 1426001 | 1429000 | Elmar 5 cm 1:35 | 1956 | 3000 |
| 1455001 | 1458000 | Elmar 5 cm 1:35 | 1956 | 3000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1946-1956 | 1 |
