180mm f/3.4 APO-Telyt-R
Revision as of 13:17, 29 March 2010 by Admin (talk | contribs)
  • Leica Order No. - 11 240 < 2947024 > 11 242 LLC - 188
  • Production era - 1975-1998 < 17,051 lenses
  • Variants - 3-cam and R-cam only versions
  • Number of lenses /groups - 7 / 4
  • F stop range - f/3.4-f/22
  • Closest focusing distance - 2.5 m / 8.2 ft
  • Smallest object field - 276 x 414 mm
  • Diaphragm setting /type -
  • Angle of view diagonal - 14 degrees
  • Filter type - E60
  • Accessories -
  • Materials -
  • Dimensions length x diameter - 135 x 68 mm / 5.31 x 2.68 in
  • Weight - 750 g /1.65 lb
  • Inscription - LEITZ CANADA APO-TELYT-R 1:3.4/180 XXXXXXX
  • Designer - Walter Mandler
  • On the street - €EU 528 in 2007
  • Forum discussion
  • Reviews
180mm f/3.4 APO-Telyt-R Serial Numbers
2748631 2749630 180mm f/3.4 APO-Telyt-R 1975 1000
2776451 2777450 180mm f/3.4 APO-Telyt-R (3-cam) 1976 1000
2814901 2815900 180mm f/3.4 APO-Telyt-R 1977 1000
2856851 2857350 180mm f/3.4 APO-Telyt-R 1977 500
2866801 2867800 180mm f/3.4 APO-Telyt-R 1977 1000
2914801 2915800 180mm f/3.4 APO-Telyt-R 1978 1000
2945701 2947200 180mm f/3.4 APO-Telyt-R 1978 1500
2987101 2988100 180mm f/3.4 APO-Telyt-R 1979 1000
2992701 2993700 180mm f/3.4 APO-Telyt-R 1979 1000
3044101 3045100 180mm f/3.4 APO-Telyt-R 1980 1000
3070801 3071800 180mm f/3.4 APO-Telyt-R 1980 1000
3072801 3073800 180mm f/3.4 APO-Telyt-R 1980 1000
3127001 3128000 180mm f/3.4 APO-Telyt-R 1981 1000
3164001 3165000 180mm f/3.4 APO-Telyt-R 1982 1000
3478901 3479100 180mm f/3.4 APO-Telyt-R 1988 200
3486401 3486700 180mm f/3.4 APO-Telyt-R 1989 300
3523796 3524295 180mm f/3.4 APO-Telyt-R 1990 500
3563873 3564372 180mm f/3.4 APO-Telyt-R 1991 500
3598820 3599219 180mm f/3.4 APO-Telyt-R 1992 400
3610680 3610979 180mm f/3.4 APO-Telyt-R 1993 300
3617886 3617886 180mm f/3.4 APO-Telyt-R 1993 1
3637626 3637775 180mm f/3.4 APO-Telyt-R 1993 150
3680031 3680430 180mm f/3.4 APO-Telyt-R 1995 400
3712003 3712302 180mm f/3.4 APO-Telyt-R 1995 300
TOTAL ASSIGNED SERIAL NUMBERS 1975-1995 17,051
