Lens Coding
Revision as of 11:16, 31 March 2010 by Admin (talk | contribs)
Lens Lens Coding Value Order No. black Order No. chrome Other lenses
Elmarit-M 21mm f/2.8 000001 1 11134
Elmarit-M 28mm f/2.8 (III) 000011 3 11804
Tele-Elmarit-M 90mm f/2.8 (II) 000100 4 11800
Summilux-M 50mm f/1.4 (II) 000101 5 11868 11856
Summicron-M 35mm f/2 (IV) 000110 6 11310 11311 Zeiss Biogon T* 2/35 ZM
Summicron-M 90mm f/2 (II) (000111) (7) 11136 11137
Elmarit-M 135mm f/2.8 (I/II) 001001 9 11829
Tri-Elmar-M 16-18-21mm f/4 ASPH. 010000 16 11626
Summicron-M 50mm f/2 (III) (010111) (23) 11817
Elmarit-M 21mm f/2.8 ASPH. 011000 24 11135 11897 Voigtländer Color Skopar 21mm 1:4,0
Zeiss Biogon T* 2,8/21 ZM
Kobalux 21mm f/2.8
Elmarit-M 24mm f/2.8 ASPH. 011001 25 11878 11898 Voigtländer Snap Shot Skopar 25mm 1:4,0
Zeiss Biogon T* 2,8/25 ZM (with mount fix)
Summicron-M 28mm f/2 ASPH. 011010 26 11604 Voigtländer Ultron 28mm 1:1,9
Elmarit-M 28mm f/2.8 (IV) 011011 27 11809
Elmarit-M 28mm f/2.8 ASPH. 011100 28 11606 Voigtländer Color Skopar 28mm 1:3,5
Zeiss Biogon T* 2,8/28 ZM
Summilux-M 35mm f/1.4 ASPH. 011101 29 11874 11883
Summicron-M 35mm f/2 ASPH[1] 011110 30 11879 11882 Voigtländer Color Skopar 35mm 1:2,5
Voigtländer Ultron 35mm 1:1,7
11821
Noctilux-M 50mm f/1 011111 31 11822
Summilux-M 50mm f/1.4 ASPH. 100000 32 11891 11892 Voigtländer Nokton 50mm 1:1,5
Zeiss C Sonnar T* 1,5/50 ZM
11819
11826
11825
Summicron-M 50mm f/2 (IV, V) 100001 33 11816 Zeiss Planar T* 2/50 ZM
Elmar-M 50mm f/2.8 100010 34 11831
(11824)
11823
Summilux-M 75mm f/1.4 100011 35 11810
11814
11815
Apo-Summicron-M 75mm f/2 ASPH. 100100 36 11637
Apo-Summicron-M 90mm f/2 ASPH. 100101 37 11884 11885
Elmarit-M 90mm f/2.8 100110 38 11807 11808
Macro-Elmar-M 90mm f/4 100111 39 11633 11634
Macro-Adaptor-M 101000 40 14409
Tri-Elmar-M 28-35-50mm f/4 ASPH. 101010 42 11890
11625
11894
To draw your lens code, use the following diagram as a guide. An example has been provided. If you prefer to draw the code while holding the lens code area towards the top, use the top diagram, otherwise use the bottom diagram.
Sources:
