135mm f/2.8 Elmarit-R II
Revision as of 14:55, 1 April 2010 by Admin (talk | contribs) (→135mm f/2.8 Elmarit-R II Serial Numbers)
- Leica Order No. - 11 211 LLC - 184
- Production era - 1968-1998 < 27,300 lenses
- Variants - ROM conversion versions
- F stop range - f/2.8-f/22
- Closest focusing distance - 1.5 m / 4.92 ft
- Diaphragm setting /type -
- Filter type - E55
- Accessories - ELPRO close focusing attachment type 4
- Materials -
- Dimensions length x diameter - 93 x 67 mm /3.66 x 2.6 in
- Weight - 730 g /1.23 lb
- Inscription - ELMARIT-R 1:2.8/135 LEITZ CANADA 2XXXXXX
- Designer - Walter Mandler
- On the street - €EU 504 in 2007
Serial numbers compiled from Puts Pocket Pod.* Lens 3178214 is 135mm f/2.8 Elmarit-M
| 2775851 | 2776350 | 135mm f/2.8 Elmarit-R | 1976 | 500 |
| 2796151 | 2798150 | 135mm f/2.8 Elmarit-R | 1976 | 2000 |
| 2809401 | 2811400 | 135mm f/2.8 Elmarit-R | 1977 | 2000 |
| 2843051 | 2845050 | 135mm f/2.8 Elmarit-R | 1977 | 2000 |
| 2886401 | 2887000 | 135mm f/2.8 Elmarit-R | 1978 | 600 |
| 2963501 | 2967000 | 135mm f/2.8 Elmarit-R | 1978 | 3500 |
| 3027801 | 3029800 | 135mm f/2.8 Elmarit-R (3-cam) | 1980 | 2000 |
| 3045101 | 3046600 | 135mm f/2.8 Elmarit-R | 1980 | 1500 |
| 3104001 | 3105000 | 135mm f/2.8 Elmarit-R | 1981 | 1000 |
| 3105501 | 3107500 | 135mm f/2.8 Elmarit-R | 1981 | 2000 |
| 3135001 | 3136800 | 135mm f/2.8 Elmarit-R | 1981 | 1800 |
| 3146501 | 3148500 | 135mm f/2.8 Elmarit-R | 1981 | 2000 |
| 3178201* | 3179200 | 135mm f/2.8 Elmarit-R | 1982 | 1000 |
| 3341201 | 3342200 | 135mm f/2.8 Elmarit-R | 1984 | 1000 |
| 3375501 | 3376000 | 135mm f/2.8 Elmarit-R | 1985 | 500 |
| 3380501 | 3381000 | 135mm f/2.8 Elmarit-R | 1985 | 500 |
| 3397601 | 3398100 | 135mm f/2.8 Elmarit-R | 1986 | 500 |
| 3405701 | 3406200 | 135mm f/2.8 Elmarit-R | 1986 | 500 |
| 3435001 | 3435500 | 135mm f/2.8 Elmarit-R | 1987 | 500 |
| 3457371 | 3457870 | 135mm f/2.8 Elmarit-R | 1988 | 500 |
| 3487251 | 3487550 | 135mm f/2.8 Elmarit-R | 1989 | 300 |
| 3507151 | 3507450 | 135mm f/2.8 Elmarit-R | 1990 | 300 |
| 3524296 | 3524795 | 135mm f/2.8 Elmarit-R | 1990 | 500 |
| 3562168 | 3562467 | 135mm f/2.8 Elmarit-R | 1991 | 300 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1976-1991 | 27,300 |
