SF 20
- Code number - 14414
- Type - Shoe mount flash unit allows TTL-flash exposure control with the R8 or R9 as well as the LEICA M6 or M7 TTL-models plus automatic flash exposure control with all other LEICA M and R cameras with central X hot-shoe contact.
- Guide No. - 65' (19.8 m)
- Angle of Coverage - 63° (35mm lens in 35mm format)
84° (24mm) with wideangle diffuser - Auto Distance Range - 23' (7.0 m), 11' (3.4 m) , 5.7' (1.7 m)
- Auto f/Stops - f/2.8, 5.6 & 11
- Flash compensation - +/- 3 EV
- Variable Power - 1/2, 1/4th & 1/8th
- TTL Dedication - Yes (if used on R8 & M6 TTL)
- Recycle Time - 5 Seconds (based on fresh batteries & full power)
- Power Source - Two 3-Volt CR123A lithium batteries
- Dimensions - 2.6 x 4.3 x 1.6" (66 x 109 x 41mm) W x H x D
- Weight - 0.38 lb (170 g)
