CM
Production era - 2004-2006 LeicaWiki.de
Type - Compact autofocus 35 mm film viewfinder camera with fixed lens
Lens - Leica Summarit 40 mm f/2.4 (6 elements / 4 groups) with multicoating Distance setting range - 0.7 m 2.3 f < ∞ LED display of focus status in each mode Smallest object field - 566 x 377 mm (reproduction ratio 1:15.7)
Autofocus system - Passive phase detection autofocus. AF auxiliary light activates in poor lighting conditions.
Exposure system - Choice of of programmed automatic exposure control mode, i.e. fully automatic exposure control with manual shift option or aperture priority exposure control mode with manual aperture pre-selection, optionally with automatic flash activation. Exposure metering - Center weighted two-zone metering (center /edge) with automatic backlighting detection (for automatic fill-in flash). Metering memory lock - Gently pressing the shutter stores the distance and exposure measurement. Exposure compensation - +/- 2 EV in 1/3 EV increments. Exposure meter range - see manufacturer's manual.
Film speed - DX-coded 25 - 5000, if outside range auto setting reverts to ISO 100.
Self timer - 2 or 10 s.
Continuous mode - 0.7 fps w/o flash. The picture series function is activated by pressing the shutter release button continuously.
Shutter speed - 1 > 1/1000s - B (T function) up to 99s
Viewfinder - Real image viewfinder with markings of the autofocus measuring field, parallax ; diopter compensation from –3 to +1 diopters ; suitable for eyeglass wearers. Display - Data indication inside the viewfinder of shutter speed, f-stop, flash condition and focus. Magification - 0.40 x, viewfinder field corresponds to approx. 90 % of the film format
Flash range - ISO 100/21° slide film 5.8 m /19 ft Guide no. : 14 m / 46 ft - SF 24D 8.5 m /28 ft Guide no. : 20 m /79 ft.
Flash modes - SCA flash units with SCA 3502M4 adapter and LEICA SF 24D can be controlled by the camera.
Data imprinting - Integrated dating device for imprinting the day and time or the date on the film.
Accessories - SF 24D flash unit, Wrist loop 18 528, Carrying strap 18 529, Electric cable release 18 540, Leather case 18 560.
Other features - Tripod socket, film cartridge window, automatic film advance ; manual start of rewinding possible ; connector for remote release.
Power supply - 3 V lithium battery CR 123A
Materials - Titanium with leather side covering.
Dimensions(W x H x D) - 116 x 64 x 43 mm / 4.57 x 2.52 x 1.69 in (lens retracted)
Weight - 300g / 10.6 oz (without battery)
- data from manufacturer's Technical Data
Brochures & Manuals
- Manual (English pages 63-119) - PDF Download
- manufacturer's manual courtesy Carson Wilson
CM Serial Numbers
| 2947801 | 2967800 | CM | 2003 | 20,000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2003 | 20,000 |
