E
Revision as of 22:29, 21 June 2010 by Admin (talk | contribs)
EAWOO -
EBOOH Everready leather case for R3 ca.1961 14615 Q
ECUUG ca.1961 37033 B
EDCUU ca.1961 37044 N
EDUUF ca.1961 37066 L
EELUD -
EEPMG Macro lamp, a circle with 4 x 25 W bulbs ? -
EEPLG Macro lamp, a circle with 4 x 40 W bulbs ? -
EEPSV Small holder for auxiliary GUHII, for screw mounting to the macro state MADAH ? -
EEPSU Larger holder for auxiliary GUHII, for screw mounting to the macro state MADAH ca. 1956 -
EEVRN Tapered bellows for large format with tape measure -
EEXRL Holder for ISOFLEX ? -
EEXRM Holder for ISOFLEX ca.1955 -
EEXSN Holder for ISOFLEX with hammer paint finish ? -
EEZYX Slide device MACRODIA for macro photography ? -
EFERN Elmar f= 13.5 cm 1:4.5 nickel finish ? -
EFGOO Everready leather case for Leica IIc, IIf, IIIc, IIIf with 50mm Summicron or Summitar and attached universal or mirror viewfinder ca.1961 -37088 K
EGIUU ca.1961 37077 P
EGOOI -
EGUUC ca.1961 37099 N
EITPL -
EKURZ Elmar f= 3.5 cm 1:3.5 chrome finish 1933-1950 -
EKURZUP Elmar f= 3.5 cm 1:3.5 nickel finish 1930-1933 -
EKUUZ ca.1961 32600 G
ELANG Elmar (II) f= 9 cm 1:4 1930-1945 -
ELANG-M Elmar (III) 1:4 / 90mm 1954-1968 -
ELCAR Early close-up lens for Compur Leica (model B) ? -
ELCAT Late close-up lens for Compur Leica (model B) 1930 -
ELCOM Early close-up lens for Compur Leica (model B) diopter No. 2 ? -
ELCON Late close-up lens for Compur Leica (model B) diopter No. 2 ? -
ELCUR Early close-up lens for Compur Leica (model B) diopter No. 3 ? -
ELCUS Late close-up lens for Compur Leica (model B) diopter No. 3 ? -
ELDIA Contact printer for 35 mm negatives Forum discussion pre 1937 -
ELDUR Contact printer to make 2 x 2” lantern slides pre 1937 [1]
ELDUS -
ELESS -
ELGAM Elmar (III) 1:4 / 90mm 1946-1963 11 830
ELGLA Metal pressure plate for ELDUR contact printer pre 1937 -
ELKIM Movie window panel 18x24 cm for contacts from Cinema negatives ? -
ELKIN Movie window panel 18x24 cm for contacts from Cinema negatives ? -
ELKOO -
ELMAR Elmar (I) f= 5 cm 1:3.5 1931-1959 -
ELMAM Elmar (III) f= 5 cm 1:3.5 with M-bayonet 1954-1961 11 610
ELMOM Elmar f= 5 cm 1:2.8 with M-bayonet 1958-1966 11 612
ELMOO Elmar f= 5 cm 1:2.8 1957-1962 -
ELPAS Close-Up lens no.1 for dial-set Compur Leica (model B) 1927 -
ELPET Close-up lens No. 3 for Elmar ? -
ELPEX Close-up lens No. 3 for Summar ? -
ELPEZ Close-up lens No. 3 for Summitar ? -
ELPIK Close-up lens No. 2 for Elmar ? -
ELPIL Close-up lens No. 2 for Summar ? -
ELPIS Close-up lens No. 2 for Summitar ? -
ELPRO Close-up lens attachments for R-50 mm, 90 mm and 135 mm 1966-2009 -
ELPUR -
ELPYN -
ELRIM Elmarit f= 9 cm 1:2.8 with bayonet mount 1959-1974 -
ELRIT Elmarit f= 9 cm 1:2.8 with screw mount 1959-1963 11 029
ELROO Elmar f= 3,5 1:4, “snap-shot” lens, prototype only ca.1950 -
ELRUU -
ELUUY -
ELZEN The “Mountain Elmar” Elmar f= 10.5 cm 1:6.3 1932-1937 -
EMQOO -
EMTOO Telyt leather case 14585 B
EMTUU 32620 T
EMUUX 32630 V
ENUUW -
EPOCH Small canvas case for LEICA III or Standard ca.1933 -
ERKOM 11128 M
ESFAB Everready leather case for LEICA III or Standard with non-colapsing Summar ca.1933 -
ESFOO Everready leather case for Leica 250 (models DD, FF & GG) 1933-1953 -
ESFUS Everready leather case for Leica IIc, IIf, IIIb, IIIc, IIIf with 50mm Summicron or Summitar ? 1938 catalog JCB's a little...IIf
ESFUSKIN Everready pigskin case for Leica IIc, IIf, IIIb, IIIc, IIIf with 50mm Summicron or Summitar ? 1938 catalog
ESMAL Everready leather case for LEICA III ca.1933 -
ESMOS Everready leather case for LEICA III or Standard with long lens ca.1933 -
ESNASKIN Everready pigskin case for LEICA II, III or Standard ca.1933 1938 catalog
ESNAR Everready leather case for LEICA II, III or Standard ca.1933 -
ESNEL Everready leather case for Leica I (model A) Forum discussion 1930 -
ESOOG Everready leather case for Leica Ic or Leica Ig JCB's a little...Ig 1949-1952 JCB's a little...Ic
ETBIX Leather lens case without strap for Summar 5 cm 1:2 ca.1933 -
ETGUS Large leather accessory case (19.5 x 24.5 x 8 cm) for camera and 5 lenses ca.1933 -
ETIFF Leather lens case with strap for Elmar 10.5 cm ca.1933 -
ETILA Leather lens case without strap for Elmar 3.5 cm ca.1933 -
ETIME Leather lens case without strap for Hektor or Elmar 5 cm ca.1933 -
ETINI Leather lens case with strap for Elmar 9 cm ca.1933 JCB's a little...IIf
ETINX Leather lens case with strap for Hektor 7.3 cm ca.1933 -
ETIPO Leather lens case with strap for Elmar or Hektor 13.5 cm ca.1933 -
ETISY Leather lens case with strap for Elmar or Hektor 13.5 cm and Elmar 3.5 cm ca.1933 -
ETKAL Small lady's canvas case for LEICA III or Standard ca.1933 -
ETMAX Large leather accessory case (22.5 x 29.5 x 8 cm) for camera and 7 lenses similar to ETGUS ca.1933 -
ETNEU Large leather accessory case (18.5 x 25.5 x 8 cm) for camera and 4 lenses similar to ETGUS ca.1933 -
ETOSA Leather lens case with strap for Hektor 7.3 cm and Elmar 3.5 cm ca.1933 -
ETRIN Leather accessory case (16 x 11 x 5 cm) for LEICA III or Standard ca.1933 -
ETRUX Small vertical leather case for LEICA III or Standard ca.1933 -
ETTAS Small canvas case for LEICA III or Standard ca.1933 -
ETTEL Small canvas case for LEICA III or Standard ca.1933 -
ETTRE Large leather accessory case (15.5 x 15.5 x 8 cm) for camera and 3 lenses similar to ETGUS ca.1933 -
ETTWO Leather accessory case (17 x 15 x 5.5 cm) for LEICA III or Standard ca.1933 -
ETXBE Small bellows, used with EEXSN and Aristophot II micro-photgraphy ? -
ETXBS Small bellows, used with Aristophot II micro-photgraphy ? -
EUKOS Everready case for Standard Leica (model E) -
EUKUT Deerskin purse for one lens filter pre 1934 -
EUROS -
EUVER -
EUVIL Morocon leather purse for one lens filter pre 1934 -
EXCOR -
EUDIT Leather case for FODUA Leica I (model A) ? -
EUSAF Small canvas case for Standard with long lens ca.1933 -
EYMZE 6-volt lamp housing with a focusing objective, and 2 blue glass filters ? -
EYMZG 6-volt lamp housing with a focusing objective, and 2 green glass filters ? -
EYMZH 6-volt lamp housing with a focusing objective, and 2 filters ? -
EZDOO Leather strap for 125mm Hektor -
