Summaron f= 3.5 cm 1:2.8
Revision as of 13:48, 22 June 2010 by Admin (talk | contribs)
  • Leica Order No. - SIMOO 11106P screw-lens; SIMOM 11306Y M2 lens; SIMWO 11106Q boxed M3 version with "specs" and caps LLC - 151
  • Production era - 1958-1963 - 5,289 screw lenses; 1958-1974 - 30,400 bayonet lenses
  • Variants - Screw, M2, and M3 with "specs", 3-crown & "Post" versions
  • Lens mount - Leica Screw and M-bayonet
  • Smallest object field -
  • Diaphragm setting /type - 10 blade
  • Angle of view diagonal - 64 degrees
  • Filter type - E39
  • Accessories - Hood: IROOA 12571, 12585, 12526, 12538; Leather case for lens with goggles: 14552
  • Materials - Chrome plated brass
  • Dimensions (length x diameter) - 29 x 51 mm / 1.14 x 2.01 in
  • Weight - 210 g /7.41 oz
  • Inscription - SUMMARON 1:2.8/3.5 LEITZ WETZLAR 1XXXXXX
Summaron f= 3.5 cm 1:2.8 Serial Numbers
.*Lens nos. 1678045, 1678231, 1678272, 1678461, 1679672 & 1679028 in this batch are 3.5 cm not 5.6 cm as listed
.** Lens nos. 1423110 & 1595665 are Summaron 3.5 cm 1:2.8
^ Lens no. 1730789 is Summaron 3.5 cm 1:2.8 (M)
1423001** 1426000 Summaron 3.5 cm 1:3.5** 1958 [3000]
1594001** 1597000 Summaron 3.5 cm 1:3.5** 1958 [3000]
1615001 1616000 Summaron 3.5 cm 1:2.8 (M2) 1958 1000
1627001 1630000 Summaron 3.5 cm 1:2.8 (M3) 1958 3000
1662001 1668000 Summaron 3.5 cm 1:2.8 (M3+S) 1959 6000
1677001 1680000 Summaron *5.6 cm 1:2.8 (M3+M+S+3crown) 1959 3000
1694001 1697000 Summaron 3.5 cm 1:2.8 (M3+M2+S) 1959 3000
1730001^ 1731100 ^Summilux 5 cm 1:1.4 1960 [1100]
1731101 1733000 Summaron 3.5 cm 1:2.8 (M3) 1960 1900
1754001 1756000 Summaron 3.5 cm 1:2.8 (S) 1960 2000
1782001 1784000 Summaron 3.5 cm 1:2.8 (M3) 1960 2000
1808001 1809000 Summaron 3.5 cm 1:2.8 1960 1000
1810001 1811000 Summaron 3.5 cm 1:2.8 (M3+M1-oliv) 1960 1000
1814001 1816000 Summaron 3.5 cm 1:2.8 1960 2000
1903001 1906000 Summaron 3.5 cm 1:2.8 (M2+S) 1961 3000
1921001 1924000 Summaron 3.5 cm 1:2.8 (M3+M2+M+S) 1962 3000
1930201 1932700 Summaron 3.5 cm 1:2.8 (M3+S) 1962 2500
1947001 1950000 Summaron 3.5 cm 1:2.8 (M3+M) 1962 3000
2006001 2007500 Summaron 3.5 cm 1:2.8 1963 1500
2049501 2051000 Summaron 3.5 cm 1:2.8 (M3) 1964 1500
2080501 2082500 Summaron 3.5 cm 1:2.8 (M2+M) 1965 2000
2100901 2102900 Summaron 3.5 cm 1:2.8 (M3+M) 1965 2000
2152551 2154550 Summaron 3.5 cm 1:2.8 (M) 1965 2000
2217201 2219200 Summaron 3.5 cm 1:2.8 (M3+M2) 1967 2000
2240001 2241000 Summaron 3.5 cm 1:2.8 1967 1000
2309751 2312750 Summaron 3.5 cm 1:2.8 (M3-black+M2+M-chrom) 1968 3000
TOTAL ASSIGNED SERIAL NUMBERS 1958-1968 52,400
