Elmar f= 5 cm 1:2.8
Revision as of 00:15, 8 September 2010 by Admin (talk | contribs) (→‎Comment)
  • Leica Order No. - ELMOO 11 112 - ELMOM 11 612 /LLC - 114
  • Production era - 1957-1962 screw lenses; 1958-1966 bayonet < 74,000 lenses
  • Variants - Metric, foot, 3-crown (on bottom ring) for Swedish army versions
  • Number of lenses /groups - 4 /3
  • F stop range - f/2.8-f/16
  • Smallest object field -
  • Diaphragm setting /type - 15 blade
  • Filter type - E39
  • Accessories - Hood: 12585, 12549
  • Materials - Chrome plated brass
  • Dimensions (collapsed flange length x diameter) - 20.94 mm / 0.6 in x 50.96 mm/ 2.0 in
  • Weight - 220 g /7.76 oz
  • Inscriptions - Elmar f=5cm 1:2.8 Nr1XXXXXX Ernst Leitz GmbH Wetzlar
    ELMAR 1:2.8 F=5cm 1XXXXXX LEITZ WETZLAR
  • Designer - Max Berek
Elmar f= 5 cm 1:2.8 Serial Numbers
1402001 1402100 Elmar 5 cm 1:28 1956 100
1438001 1440000 Elmar 5 cm 1:28 (S) 1956 2000
1450001 1455000 Elmar 5 cm 1:28 (S) 1956 5000
1494001 1497000 Elmar 5 cm 1:28 (S) 1957 3000
1537501 1541000 Elmar 5 cm 1:28 (S) 1957 3500
1549001 1552000 Elmar 5 cm 1:28 (M+S) 1958 3000
1574001 1578000 Elmar 5 cm 1:28 (M+S) 1958 4000
1589001 1592000 Elmar 5 cm 1:28 (M) 1958 3000
1600001 1603000 Elmar 5 cm 1:28 (M) 1958 3000
1617001 1621000 Elmar 5 cm 1:28 (M+S+S3crown) 1958 4000
1624001 1627000 Elmar 5 cm 1:28 (M) 1958 3000
1632501 1638500 Elmar 5 cm 1:28 (S3crown) 1958 6000
1668001 1671000 Elmar 5 cm 1:28 (M) 1959 3000
1697751 1700000 Elmar 5 cm 1:28 1959 2250
1721501 1725000 Elmar 5 cm 1:28 1960 3500
1727001 1730000 Elmar 5 cm 1:28 (M) 1960 3000
1819001 1822000 Elmar 5 cm 1:28 (M) 1960 3000
1838001 1840000 Elmar 5 cm 1:28 1961 2000
1909001 1912000 Elmar 5 cm 1:28 1961 3000
1912000 1936000 Elmar 5 cm 1:28 (M) 1962 3300
1989001 1991000 Elmar 5 cm 1:28 1963 2000
2073501 2074500 Elmar 5 cm 1:28 (M) 1964 1000
2119151 2121150 Elmar 5 cm 1:28 (M) 1965 2000
2161501 2162500 Elmar 5 cm 1:28 1966 1000
2186901 2188900 Elmar 5 cm 1:28 (M) 1966 2000
2237001 2238000 Elmar 5 cm 1:28 (M) 1967 1000
2326301 2327800 Elmar 5 cm 1:28 1969 1500
2472501 2473250 Elmar 5 cm 1:28 (M) 1971 750
2503001 2503100 Elmar 5 cm 1:28 1971 100
TOTAL ASSIGNED SERIAL NUMBERS 1956-1971 74,000
