B
Leitz "Binoculars" data courtesy of Peter Abrahams
| BANAN | - | ||
| BALGT | Adjustment bellows, for screw mounting to various Leica Adapter Rings | ? | - |
| BATCA | - | ||
| BDFUU | - | ||
| BAZOO | Copy stand, superseded BESAL copy stand | ? | - |
| BAZOS | Copy stand BAZOO, NY designation | ? | - |
| BEECH | Lamp for MONLA Microscope, DC current | ? | - |
| BEEUL | Lamp for MONLA Microscope, AC current | ? | - |
| BEHOO | Copy stand for Elmar or Summar 5 cm, 1:1.5; 1: 2.1: 3 Forum discussion | 1935-1959 | replaced BEMAR & BESOT |
| BEINS | 1:1 copy stand for Elmar 3.5 cm | 1931 | - |
| BEKUR | Copy stand for Elmar 3.5 cm with 3 extension rings for 1:1.5, 1:2, 1:3 | 1931 | - |
| BEKUS | Copy stand for Elmar 35 mm with 3 extension rings for 1:1.5, 1:2, 1:3 | ? | - |
| BELOS | Small lamp with adjustable bracket and 25 watt bulb | pre 1934 | - |
| BELUN | 1:1 copy stand w/extension tube for 50mm Elmar Forum discussion | 1932-1958 | Forum discussion |
| BELUNHESUM | 1:1 closeup stand w/extension tube for Summitar | ? | - |
| BEMAR | Copy stand for Elmar 5 cm with 3 extension rings for 1:1.5, 1:2, 1:3 | 1932 | - |
| BEMTI | - | ||
| BEOON | Offset copy stand for 1:1 reproductions with M-5 cm lenses Forum discussion [1] [2] [3] | 1959-1970 | - also 16511 |
| BEOOS | Offset copy stand for 1:1 reproductions with M-3.5 cm lenses | ? | - |
| BEOOY | Copy stand for Elmar, Hektor or Summar 5cm with 3 supplementary lenses | 1935-1951 | - |
| BERAT | 25 watt bulb for BELOS adjustable lamp | 1934 | - |
| BERIN | Intermediate collar and clamping ring for BEMAR for reproduction at 1:1 | 1932 | - |
| BESAL | Copy stand combining BEVOR, BETAB and BEMAR with 3 extension rings for 1:1 reproduction with Elmar 5 cm | 1933 | - |
| BESOT | Copy stand for Summar 5cm with 3 extension rings for 1:1.5, 1:2, 1:3 | ? | - |
| BESUM | 1:1 copy stand w/extension tube for Summar 5 cm | 1935 | - |
| BETAB | 4 legs for BEVOR with closeup lens No. 2 | ? | - |
| BETRY | 3 legs for BELUN and BESUM | ? | - |
| BEUUY | Extension tube | - | |
| BEUUY-IZUUS | - | ||
| BEVOR | Copy stand for Elmar or Hektor 5cm with 3 supplementary lenses | 1931 | - superseded by BEOOY |
| BFOOX | Desk viewer with zoom lens, 2 film coils and lighting, for Leica USA | ? | - |
| BIDAL | Binoculars – 6 x 15 - 7 deg | 1925-1939 | - |
| BIDOX | Binoculars – 6 x 30 – 8.5 deg | ca.1927-1939 | - |
| BIDOXIT | Binoculars – 6 x 30 – 8.5 deg – CF type | ca.1927-1962 | - |
| BILOM | Binoculars – 8 x 30 – 6.3 deg | 1930-ca.1935 | - |
| BILOMIT | Binoculars – 8 x 30 – 8.5 deg – CF type | 1930-ca.1935 | - |
| BILUSTRA | Binoculars – 3 x 13.5 – 13.7 deg | 1921-1950s | - |
| BIMAX | Binoculars – 8 x 24 – 8.5 deg | ca.1930-1935 | - |
| BIMAXIT | Binoculars – 8 x 24 – 8.5 deg – CF type | ca.1930-1935 | - |
| BIMULIORA | Binoculars – 4 x 16 | 1921-ca.1926 | - |
| BINAR | Binoculars – 3 x 13.5 – 13.7 deg | 1921-1950s | - |
| BINOCLE | Binoculars – 6 x 18 | May 14, 1907 | - first commercially available Leitz binoculars |
| BINOCT | Binoculars – 8 x 26 | 1914-ca.1926 | - |
| BINODAL | Binoculars – 6 x 21 – 8 deg | 1919 | - |
| BINOFORTE | Binoculars – 12 x 46 | 1913 | - 12 x 42 in 1914 |
| BINOFORTIM | Binoculars – 12 x 46 – CF type | 1913 | - 12 x 42 in 1914 |
| BINOL | Binoculars – 6 x 24 – 8.5 deg | ca.1927-1939 | - |
| BINOLAS | Binoculars – 6 x 21 – 8 deg – CF type | 1919 | - |
| BINOLI | Binoculars – 6 x 24 | 1914-ca.1926 | - |
| BINOLIT | Binoculars – 6 x 24 – 8.5 deg – CF type | ca.1927-1939 | - |
| BINOM | Binoculars – 8 x 24 – 6.5 deg | 1913 | - 8 x 26 1914-ca.1926 |
| BINOMA | Binoculars – 8 x 24 – 6.5 deg | 1913 | - heavy version of BINOM |
| BINOMAT | Binoculars – 8 x 24 – 6.5 deg – CF type | 1914 | - |
| BINDOMAT | - | ||
| BINOMIA | Binoculars – 8 x 24 – 6.5 deg – CF type | 1913 | - |
| BINOMINIA | Binoculars – 4 x 16 – 11 deg – CF type | 1914 | - |
| BINOMINIOS | Binoculars – 4 x 16 – CF type | 1912-1914 | - theater glasses |
| BINOMINOS | Binoculars – 4 x 16 – CF type | 1914 | - heavier theater glasses |
| BINOPLASTICO | Binoculars – 30 x 90 – 1.5 deg | 1920 | - |
| BINOSPO | Binoculars – 6 x 24 – CF type | 1914-ca.1926 | - |
| BINOT | Binoculars – 6 x 30 | 1912-ca.1926 | - |
| BINOTOUR | Binoculars – 6 x 16 – CF type | 1914 | - |
| BINOTRIX | 3 oculars x 90 | 1920s | - on turret at 90 deg |
| BINOVISTA | Binoculars – 15 x 60 – 3.5 deg | 1920 | - |
| BINOXYD | Binoculars – 6 x 30 – CF type | 1912-ca.1926 | - |
| BINOZE | Binoculars – 10 x 42 | 1912 | - |
| BINOZITO | Binoculars – 10 x 46 – CF type | 1913 | - |
| BINUX | Binoculars – 8 x 30 – 8.5 deg | 1927-1962 | - |
| BINUXIT | Binoculars – 8 x 30 – 8.5 deg – CF type | 1927-1962 | - |
| BIOCT | Binoculars – 8 x 24 – 6.3 deg | ca.1927-1939 | - |
| BIOCTIT | Binoculars – 8 x 24 – 6.3 deg – CF type | ca.1927-1939 | - |
| BISEXIT | Binoculars – 6 x 21 – 8.5 deg – CF type | 1925-1931 | - |
| BITUR | Binoculars – 4 x 20 – 10.3 deg | ca.1925-1959 | - |
| BIZWE | Binoculars – 12 x 42 | 1912 | - |
| BKUUT | - | ||
| BLIAU | Trigger for flash | ? | - |
| BLISE | - | ||
| BLITZ | Flash as a replacement for BUNOO, New York | ? | - |
| BOOWU | Copy stand for screw lenses of focal length 5 cm, recording format, A4, A5, A6 Forum discussion | 1952-1962 | - also 16525 |
| BOOWU-M | Copy stand for M lenses of focal length 5 cm, recording format, A4, A5, A6 . | 1956-1976 | - also 16526 and later BOWUM |
| BOOXZ | 7mm extension tube for V: 1:2.5 for use with with ZWTOO | ? | - |
| BPCUU | - | ||
| BQCOO | A36 Blue filter | 1955 | - |
| BRACK | Holder for SYNCO / FLASH in the vertical position | ? | - |
| BRUUM | Small projector VIIIa interchangeable condenser lens for 5 cm focus | pre 1937 | - |
| BSIUU | - | ||
| BSUUA | - | ||
| BTLOO | Flash unit for 2 flash bulbs for Leica I, II and IIIa | ? | - |
| BTSOO | Flash unit for 2 flash bulbs for Leica IIIb/c | ? | - |
| BTOOK | Flash unit for 2 flash bulbs for Leica Standard | ? | - |
| BTLOL | Flash unit for 2 flash bulbs for Leica IIId? | ? | - |
| BUNOO | Flash unit with internal synchronization for Leica IIIb or earlier; base-plate with 3/8" tripod socket, electrical contact pin and adjustment screw | ? | - |
| BUUGR | Leitz briefcase projector, with lens | 1934 | - |
| BUOOP | - | ||
| BUUDC | - | ||
| BUUQI | - | ||
| BUURW | - | ||
| BUUWM | - | ||
| BUUYN | - | ||
| BWOOG | Large battery container for flash unit | ? | - |
| BWOOH | Large battery container for flash unit | ? | - |
| BWOOL | Large battery container for flash unit | ? | - |
| BWOOK | Large battery container for flash unit | ? | - |
| BWOON | Large battery container for professional flash unit | ? | - |
| BWOOP | Large battery container for flash unit with maximum performance | ? | - |
