Summaron f= 3.5 cm 1:2.8
Revision as of 22:24, 27 October 2010 by Admin (talk | contribs) (→Summaron f= 3.5 cm 1:2.8 Serial Numbers)
- Leica Order No. - SIMOO screw-lens; SIMOM 11306 M-version; SIMWO 11106 M3 version with "specs" and caps LLC - 151
- Production era - 1958-1963 - 5,289 screw lenses; 1958-1974 - 30,400 bayonet lenses
- Variants - Screw, M-bayonet, and M3 with "specs", 3-crown & "Post" versions
- Lens mount - Leica Screw and M-bayonet
- Lens /groups - 6 /?
- F stop range - f/2.8-f/22
- Smallest object field - 430 x 640 mm - 390 x 590 mm (M3)
- Angle of view diagonal - 64 degrees
- Filter type - E39 - A42
- Accessories - Hood: IROOA 12571, 12585, 12526, 12538; Leather case for lens with goggles: 14552
- Dimensions (length x diameter) - 29 x 51 mm / 1.14 x 2.01 in
- Weight - 210 g /7.41 oz
- Inscription - SUMMARON 1:2.8/3.5 LEITZ WETZLAR 1XXXXXX
- On the street - $US 450 (S) - 650 (M2) - 590 (M3) in 2010
Serial numbers compiled from Puts Pocket Pod.*Lens nos. 1678045, 1678231, 1678272, 1678461, 1679672 & 1679028 in this batch are 3.5 cm not 5.6 cm as listed
.** Lens nos. 1423110 & 1595665 are Summaron 3.5 cm 1:2.8
^ Lens no. 1730789 is Summaron 3.5 cm 1:2.8 (M)
1423001** | 1426000 | Summaron 3.5 cm 1:3.5** | 1958 | [3000] |
1594001** | 1597000 | Summaron 3.5 cm 1:3.5** | 1958 | [3000] |
1615001 | 1616000 | Summaron 3.5 cm 1:2.8 (M) | 1958 | 1000 |
1627001 | 1630000 | Summaron 3.5 cm 1:2.8 (M3) | 1958 | 3000 |
1662001 | 1668000 | Summaron 3.5 cm 1:2.8 (M3+S) | 1959 | 6000 |
1677001 | 1680000 | Summaron *5.6 cm 1:2.8 (M3+M+S+3crown) | 1959 | 3000 |
1694001 | 1697000 | Summaron 3.5 cm 1:2.8 (M3+M+S) | 1959 | 3000 |
1730001^ | 1731100 | ^Summilux 5 cm 1:1.4 | 1960 | [1100] |
1731101 | 1733000 | Summaron 3.5 cm 1:2.8 (M3) | 1960 | 1900 |
1754001 | 1756000 | Summaron 3.5 cm 1:2.8 (S) | 1960 | 2000 |
1782001 | 1784000 | Summaron 3.5 cm 1:2.8 (M3) | 1960 | 2000 |
1808001 | 1809000 | Summaron 3.5 cm 1:2.8 | 1960 | 1000 |
1810001 | 1811000 | Summaron 3.5 cm 1:2.8 (M3+M1-oliv) | 1960 | 1000 |
1814001 | 1816000 | Summaron 3.5 cm 1:2.8 | 1960 | 2000 |
1903001 | 1906000 | Summaron 3.5 cm 1:2.8 (M+S) | 1961 | 3000 |
1921001 | 1924000 | Summaron 3.5 cm 1:2.8 (M3+M+S) | 1962 | 3000 |
1930201 | 1932700 | Summaron 3.5 cm 1:2.8 (M3+S) | 1962 | 2500 |
1947001 | 1950000 | Summaron 3.5 cm 1:2.8 (M3+M) | 1962 | 3000 |
2006001 | 2007500 | Summaron 3.5 cm 1:2.8 | 1963 | 1500 |
2049501 | 2051000 | Summaron 3.5 cm 1:2.8 (M3) | 1964 | 1500 |
2080501 | 2082500 | Summaron 3.5 cm 1:2.8 (M) | 1965 | 2000 |
2100901 | 2102900 | Summaron 3.5 cm 1:2.8 (M3+M) | 1965 | 2000 |
2152551 | 2154550 | Summaron 3.5 cm 1:2.8 (M) | 1965 | 2000 |
2217201 | 2219200 | Summaron 3.5 cm 1:2.8 (M3+M) | 1967 | 2000 |
2240001 | 2241000 | Summaron 3.5 cm 1:2.8 | 1967 | 1000 |
2309751 | 2312750 | Summaron 3.5 cm 1:2.8 (M3+M-black+M-chrom) | 1968 | 3000 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1958-1968 | 52,400 |
