90mm f/2.8 Elmarit-R II
Revision as of 16:38, 9 November 2010 by Admin (talk | contribs) (→90mm f/2.8 Elmarit-R II Serial Numbers)
- Leica Order No. - 11 806 - 11 154 LLC - 173
- Production era - 1980-1998 < 16,615 lenses
- Variants - 2-cam, 3-cam, R-only, Canada & Germany versions
- Number of lenses /groups - 4 / 4
- F stop range - f/2.8-f/22
- Closest focusing distance - 70 cm / 2.30 ft
- Smallest object field -
- Diaphragm setting /type -
- Filter type - E55
- Accessories - ELPRO close focusing attachment type 3
- Materials -
- Weight - 450 g /0.99 lb
- Inscription - ELMARIT-R 1:2.8/90 LEITZ CANADA 2XXXXXX
LEICA ELMARIT-R 1:2.8/90 E 55 3XXXXXX
LEITZ ELMARIT-R 1:2.8/90 3XXXXXX - Designer - Walter Mandler
^ Lens 2988534 is Elmarit - R 2.8 / 135Serial numbers compiled from Puts Pocket Pod
2908101 | 2909100 | 90mm f/2.8 Elmarit-R | 1978 | 1000 |
2929901 | 2931000 | 90mm f/2.8 Elmarit-R | 1978 | 1100 |
2982101 | 2982600 | 90mm f/2.8 Elmarit-R | 1979 | 500 |
2988101 | ^ 2989100 | 90mm f/2.8 Elmarit-R | 1979 | 1000 |
3088001 | 3089000 | 90mm f/2.8 Elmarit-R | 1981 | 1000 |
3250101 | 3251100 | 90mm f/2.8 Elmarit-R | 1983 | 1000 |
3260101 | 3261100 | 90mm f/2.8 Elmarit-R | 1983 | 1000 |
3300201 | 3301200 | 90mm f/2.8 Elmarit-R | 1984 | 1000 |
3323201 | 3324200 | 90mm f/2.8 Elmarit-R (3-cam) | 1984 | 1000 |
3344201 | 3346200 | 90mm f/2.8 Elmarit-R (ELC.2-cam) | 1984 | 2000 |
3376001 | 3377000 | 90mm f/2.8 Elmarit-R | 1985 | 1000 |
3384201 | 3386000 | 90mm f/2.8 Elmarit-R | 1986 | 1800 |
3408701 | 3408890 | 90mm f/2.8 Elmarit-R | 1986 | 190 |
3551468 | 3553467 | 90mm f/2.8 Elmarit-R (R-only) | 1991 | 2000 |
3616580 | 3617079 | 90mm f/2.8 Elmarit-R | 1993 | 500 |
3637101 | 3637325 | 90mm f/2.8 Elmarit-R | 1993 | 225 |
3660531 | 3660830 | 90mm f/2.8 Elmarit-R (11 154) | 1994 | 300 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1978-1994 | 16,615 |
