Summicron (I) f= 5 cm 1:2
Revision as of 15:44, 17 November 2010 by Admin (talk | contribs) (→Summicron (I) f= 5 cm 1:2 Serial Numbers)
- Leica Order No. - SOOIC, SOSTA, M-bayonet: SOOIC-M, 11118 (M-rigid-chrom), SOSIC 11818 (M-rigid.chrom), SOMNI 11918 (M-DR-chrom) /LLC - 118
- Production era - 1953-1969 Serial Nos. - 920000- screw-mount; 1112000- M-mount < 253,314 lenses
- Variants - Collapsible, rigid, rigid Dual Range (DR); Compur shutter (CS), chrome and black; duel lever (s/n 920022)
- Compatibility - DR version cannot be used on M8 or M9 cameras and the collapsible type can only be used fully extended.
- Number of lenses /groups - 7 /4 - 4 /4 (collapsible)
- F stop range - f/2-f/16
- Smallest object field - 410 x 620 mm
- Diaphragm setting /type - 10-blade - 16-blade 11 918 & 11 818
- Filter type - E39 - A42
- Accessories - Hood: SOOFM - IROOA; Viewfinder: SBOOI 12015; Close-focus attachment for DR lens: SDPOO (for proper fit last 4 digits of serial nos. must match); close focus for collapsible or rigid lens: SOMKY+ UOORF
- Weight - 220 g /7.76 oz screw, 285 g /10.06 oz bayonet
- Inscription - Summicron f=5cm 1:2 9XXXXX Ernst Leitz [GmbH] Wetzlar
- Designer - Gustav Kleinberg
- On the street - $US 425 (collapsible-M) - 250 (collapsible-S) - 300 (DR) - 700 (rigid-M) - 1,900 (rigid-S) in 2010
- Marco Cavina 1
- Marco Cavina 2
- Erwin Puts - (2/50 is at bottom of page)
Serial numbers compiled from Puts Pocket Pod.* Lens 1628616 is black Elmar 3.5/5cm head with iris diaphragm, no focusing mount
.** Lens nos. 1950022 & 1950025 are M-2/50 DR
^ Lens 1176510 is Summaron 3.5 cm 1:3.5 (M)
^^ Lens no. 1571311 is Summicron 3.5 cm 1:2 (ELW.M-chrom)
^^^ Lens 1363725 is Elmar 5 cm 1:3.5 (RS)
| 920000 | 930000 | Summicron f= 5 cm 1:2 (M+S-collapsible) | 1951 | 10001 |
| 959001 | 960000 | Summicron f= 5 cm 1:2 | 1952 | 1000 |
| 993001 | 996000 | Summicron f= 5 cm 1:2 (S-collapsible) | 1952 | 3000 |
| 1009001 | 1010000 | Summicron f= 5 cm 1:2 | 1952 | 1000 |
| 1020001 | 1025000 | Summicron f= 5 cm 1:2 | 1952 | 5000 |
| 1040001 | 1045000 | Summicron f= 5 cm 1:2 (S-collapsible) | 1952 | 5000 |
| 1091001 | 1097000 | Summicron f= 5 cm 1:2 (S-collapsible) | 1953 | 6000 |
| 1103001 | 1106000 | Summicron f= 5 cm 1:2 | 1953 | 3000 |
| 1113438 | 1114000 | Summicron f= 5 cm 1:2 | 1953 | 563 |
| 1114001 | 1119000 | Summicron f= 5 cm 1:2 (M-collapsible) | 1953 | 5000 |
| 1124701 | 1127000 | Summicron f= 5 cm 1:2 | 1954 | 2300 |
| 1143001 | 1145000 | Summicron f= 5 cm 1:2 (M-collapsible) | 1954 | 2000 |
| 1152001 | 1157000 | Summicron f= 5 cm 1:2 (CS+S-collapsible) | 1954 | 5000 |
| 1166001 | 1170000 | Summicron f= 5 cm 1:2 | 1954 | 4000 |
| 1172501 | 1175000 | Summicron f= 5 cm 1:2 | 1954 | 2500 |
| 1175501 | ^1178000 | Summicron f= 5 cm 1:2 | 1954 | 2500 |
| 1190001 | 1195000 | Summicron f= 5 cm 1:2 (M-collapsible) | 1954 | 5000 |
| 1195001 | 1198000 | Summicron f= 5 cm 1:2 | 1954 | 3000 |
| 1203001 | 1206000 | Summicron f= 5 cm 1:2 | 1954 | 3000 |
| 1215001 | 1220000 | Summicron f= 5 cm 1:2 (S+M-collapsible) | 1954 | 5000 |
| 1231101 | 1236000 | Summicron f= 5 cm 1:2 (S-collapsible) | 1954 | 4900 |
| 1252001 | 1256000 | Summicron f= 5 cm 1:2 | 1955 | 4000 |
| 1263001 | 1268000 | Summicron f= 5 cm 1:2 (M+S-collapsible) | 1955 | 5000 |
| 1277001 | 1282000 | Summicron f= 5 cm 1:2 (M-collapsible) | 1955 | 5000 |
| 1300701 | 1305000 | Summicron f= 5 cm 1:2 | 1955 | 4300 |
| 1315001 | 1320000 | Summicron f= 5 cm 1:2 (M+S-collapsible) | 1955 | 5000 |
| 1325501 | 1330000 | Summicron f= 5 cm 1:2 (S-collapsible) | 1955 | 4500 |
| 1348001 | 1353000 | Summicron f= 5 cm 1:2 (M-collapsible) | 1956 | 5000 |
| 1363501^^^ | 1366000 | Summicron f= 5 cm 1:2 | 1956 | 2500 |
| 1368501 | 1371000 | Summicron f= 5 cm 1:2 | 1956 | 2500 |
| 1375001 | 1380000 | Summicron f= 5 cm 1:2 (M-collapsible) | 1956 | 5000 |
| 1393001 | 1396750 | Summicron f= 5 cm 1:2 (M-collapsible) | 1956 | 3750 |
| 1400001 | 1401000 | Summicron f= 5 cm 1:2 (M-DR+M-rigid-chrom) | 1956 | 1000 |
| 1401001 | 1402000 | Summicron f= 5 cm 1:2 | 1956 | 1000 |
| 1402201 | 1405000 | Summicron f= 5 cm 1:2 | 1956 | 2800 |
| 1446001 | 1450000 | Summicron f= 5 cm 1:2 (M-DR+M-rigid-chrom) | 1956 | 4000 |
| 1465001 | 1470000 | Summicron f= 5 cm 1:2 (M-DR-chrom) | 1957 | 5000 |
| 1473001 | 1477000 | Summicron f= 5 cm 1:2 (M-DR-chrom+black) | 1957 | 4000 |
| 1478501 | 1481700 | Summicron f= 5 cm 1:2 (S-collapsible) | 1957 | 5000 |
| 1510001 | 1515000 | Summicron f= 5 cm 1:2 (M-rigid+DR-chrom) | 1957 | 5000 |
| 1530001 | 1535000 | Summicron f= 5 cm 1:2 (M-DR+M-rigid-chrom) | 1957 | 5000 |
| 1541001 | 1546000 | Summicron f= 5 cm 1:2 (M-DR+M-rigid-chrom) | 1957 | 5000 |
| 1567001^^ | 1572000 | Summicron f= 5 cm 1:2 (M-DR-chrom+M-rigid-black) | 1958 | 5000 |
| 1578501 | 1580000 | Summicron f= 5 cm 1:2 | 1958 | 1500 |
| 1581001 | 1583000 | Summicron f= 5 cm 1:2 (M+S-rigid-chrom) | 1958 | 2000 |
| 1585101 | 1588000 | Summicron f= 5 cm 1:2 (M-DR+M+S-rigid-chrom+M-rigid-black) | 1958 | 2900 |
| 1592001 | 1594000 | Summicron f= 5 cm 1:2 (S-chrom+M-DR-chrom) | 1958 | 2000 |
| 1597001 | 1600000 | Summicron f= 5 cm 1:2 (M+DR+S-rigid-chrom) | 1958 | 3000 |
| 1605501 | 1608000 | Summicron f= 5 cm 1:2 (S-rigid-chrom+M-DR-chrom) | 1958 | 2500 |
| 1623001 | 1624000 | Summicron f= 5 cm 1:2 (M-DR+rigid-chrom-11818) | 1958 | 1000 |
| 1704001 | 1709000 | Summicron f= 5 cm 1:2 (S-rigid+DR-chrom) | 1959 | 5000 |
| 1749501 | 1752000 | Summicron f= 5 cm 1:2 | 1960 | 2500 |
| 1762001 | 1765000 | Summicron f= 5 cm 1:2 (M-DR+S-chrom) | 1960 | 3000 |
| 1784001 | 1788000 | Summicron f= 5 cm 1:2 (M-rigid-chrom) | 1960 | 4000 |
| 1811001 | 1814000 | Summicron f= 5 cm 1:2 (M-rigid-chrom) | 1960 | 3000 |
| 1831001 | 1838000 | Summicron f= 5 cm 1:2 (S-chrom+M-DR-chrom+black) | 1961 | 7000 |
| 1885001 | 1888000 | Summicron f= 5 cm 1:2 (M-rigid-chrom) | 1961 | 3000 |
| 1894801 | 1896000 | Summicron f= 5 cm 1:2 (M-rigid) | 1961 | 1200 |
| 1924001 | 1927000 | Summicron f= 5 cm 1:2 (M-rigid.bleck+chrom) | 1962 | 3000 |
| 1942001 | 1945000 | Summicron f= 5 cm 1:2 | 1962 | 3000 |
| 1950001 | **1951000 | Freigehalten (M-DR-chrom) | 1962 | [1000] |
| 1951001 | 1953000 | Summicron f= *5 cm 1:2 (M-DR-chrom) | 1962 | 2000 |
| 1954001 | 1957000 | Summicron f= 5 cm 1:2 (M+DR-chrom+M-rigid-black) | 1962 | 3000 |
| 1961001 | 1964000 | Summicron f= 5 cm 1:2 (M-rigid-chrom-11818) | 1962 | 3000 |
| 1984401 | 1988000 | Summicron f= 5 cm 1:2 (11118) | 1963 | 3600 |
| 2031001 | 2033000 | Summicron f= 5 cm 1:2 (M-rigid-black+M-DR-chrom) | 1964 | 2000 |
| 2036001 | 2037000 | Summicron f= 5 cm 1:2 | 1964 | 1000 |
| 2052001 | 2054000 | Summicron f= 5 cm 1:2 | 1964 | 2000 |
| 2091501 | 2093500 | Summicron f= 5 cm 1:2 (M-rigid+DR-chrom) | 1965 | 2000 |
| 2095501 | 2097500 | Summicron f= 5 cm 1:2 | 1965 | 2000 |
| 2106801 | 2108800 | Summicron f= 5 cm 1:2 | 1965 | 2000 |
| 2114551 | 2117550 | Summicron f= 5 cm 1:2 (M-DR) | 1965 | 3000 |
| 2139951 | 2142950 | Summicron f= 5 cm 1:2 (M-rigid-chrom) | 1965 | 3000 |
| 2159001 | 2161000 | Summicron f= 5 cm 1:2 (M-DR+M-rigid.chrom) | 1966 | 2000 |
| 2180901 | 2182900 | Summicron f= 5 cm 1:2 (M-rigid-chrom) | 1966 | 2000 |
| 2228301 | 2229300 | Summicron f= 5 cm 1:2 (M-rigid+DR-chrom) | 1967 | 1000 |
| 2233801 | 2235800 | Summicron f= 5 cm 1:2 (M-rigid+DR-chrom) | 1967 | 2000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1951-1967 | 253,314 |
Lens superseded by Summicron (II) f= 5 cm 1:2
