Digilux 2
3D image Click-to-turn view
Code number - 18 255
Focus range - Close-up limit 30 cm (ca. 12 inches) and 15 cm with ELPRO-D E69.
Accessories - Black leather case 18627, Li-ion Battery, UVa Filter, 4x ND Filter, Filter Holder, SF 24D Flash Unit, and the ELPRO-D E69 to extend focusing limits in the close-focus range - Electronic Cable Release: 18626 CR-DC1 - Manual Cable Release: 14076
Specifications - adapted from manufacturer's technical data of June 2006. Leica Digilux 2 Data
Manuals & brochures
Forum discussion
- Digilux 2 User Group
- [1]
- [2]
- [3]
- [4]
- [5]
- [6]
- [7]
- [8]
- [9]
- [10]
- [11] [12]
- [13]
- [14]
- [15]
- [16]
- [17] [18] [19]
- [20]
- [21] [22] [23]
- [24]
- [25]
Reviews
Digilux 2 Serial Numbers
Serial numbers compiled from Puts Pocket Pod^ Camera 2999690 is Digilux 2
| 2984401 | 2999400 | Digilux 2 | 2003 | 15,000 |
| 2999401 ^ | 2999997 | MP ^ | 2003 | [597] |
| 3004001 | 3005000 | Digilux 2 | 2004 | 1,000 |
| 3011101 | 3026100 | Digilux 2 | 2004 | 15,000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2003-2004 | 31,000 |
