35mm f/2.8 Elmarit-R I
Revision as of 17:15, 12 December 2010 by Admin (talk | contribs)
  • Leica Order No. - 11101 (1964-68), 11201 (1968-73) / LLC - 158
  • Production era - 1964-1973 (1964-1965 ca. 200 chrome lenses) < 31,950 lenses
  • Variants - 1-cam, 2-cam, 3-cam; black and chrome versions
  • Note - The chrome finish was made for the Leicaflex. Fewer than 200 were made, and once it was found that the finish could reflect extraneous light in to the meter cell, this finish was discontinued in favor of black. chaos '06
  • Number of lenses /groups - 7 / 6
  • F stop range - f/2.8-f/22 in half-stops
  • Closest focusing distance - 30 cm / 11.81 in
  • Smallest object field - 140 x 210 mm
  • Diaphragm setting /type - 6-blade
  • Angle of view diagonal - 64 degrees
  • Filter type - Series 6 + 14160
  • Accessories - Hood: 12564, Front cap: 14163
  • Materials -
  • Dimensions length x diameter - 40 x 63 mm / 1.57 x 2.48 in
  • Weight - 310 g /14.46 oz
  • Inscriptions - ELMARIT-R 1:2.8/35 LEITZ WETZLAR 1XXXXXX
    LEITZ ELMARIT-R 1:2.8/35 2XXXXXX
  • Designer - Rudolph Ruehl 1964
35mm f/2.8 Elmarit-R I Serial Numbers
.* Lens 2064302 is 2.8/135mm Elmarit-M
1972001 1972100 35mm f/2.8 Elmarit-R (1-cam.chrom) 1963 100
1995001 1995500 35mm f/2.8 Elmarit-R (1-cam.chrom+black) 1963 500
2020001 2022000 35mm f/2.8 Elmarit-R 1964 2000
2034001 2035000 35mm f/2.8 Elmarit-R 1964 1000
2041701 2042700 35mm f/2.8 Elmarit-R 1964 1000
2063501 *2065500 *35mm f/2.8 Elmarit-R 1964 2000
2099901 2100900 35mm f/2.8 Elmarit-R 1965 1000
2154551 2154900 35mm f/2.8 Elmarit-R 1965 350
2168701 2170700 35mm f/2.8 Elmarit-R (3-cam.black) 1966 2000
2176901 2178900 35mm f/2.8 Elmarit-R 1966 2000
2184901 2186900 35mm f/2.8 Elmarit-R 1966 2000
2201101 2203100 35mm f/2.8 Elmarit-R 1966 2000
2252401 2254400 35mm f/2.8 Elmarit-R (black) 1967 2000
2276251 2278250 35mm f/2.8 Elmarit-R 1968 2000
2336801 2338800 35mm f/2.8 Elmarit-R (2-cam.black) 1969 2000
2364001 2366000 35mm f/2.8 Elmarit-R 1969 2000
2409001 2411000 35mm f/2.8 Elmarit-R (black) 1970 2000
2428751 2430750 35mm f/2.8 Elmarit-R (1-cam.chrom+black) 1970 2000
2450001 2452000 35mm f/2.8 Elmarit-R 1970 2000
2468501 2470500 35mm f/2.8 Elmarit-R 1971 2000
TOTAL ASSIGNED SERIAL NUMBERS 1963-1971 31,950
Lens superseded by 35mm f/2.8 Elmarit-R II
