35mm f/1.4 ASPH.2 Summilux-M
Revision as of 21:22, 4 January 2011 by Admin (talk | contribs)
  • Leica Order No. - 11 663-black - -titanium
  • Production era - 2010-Current
  • Serial numbers - -4095807-
  • Angle of view (diagonal, horizontal, vertical) For 35 mm format (24 x 36 mm): 63°, 54°, 37°, for M8 & M8.2 (18 x 27 mm): 49°, 42°, 28°, equivalent to approx. 47 mm for 35 mm format
  • Optical design
    • Number of lenses/groups - 9 /5
    • Focal length - 35.6 mm
    • Aspherical surfaces - 1
    • Position of entrance pupil - 16.6 mm from the apex of the first lens element
  • Distance settings
    • Focusing range - 0.7 m to ∞
    • Scales - Combined meter /feet graduation
    • Smallest object field/ Largest reproduction ratio - For 35 mm format: approx. 418 × 626 mm /1:17.4 (for M8 approx. 313 × 470 mm /1:17.4)
  • Aperture
    • Setting/function - f/1.4-16 with click-stops, half values available /9 blade
  • Mount - Leica M quick-change bayonet with 6-bit bar-coding for digital M-models
  • Filter - Inner threading for E46 screw-in filters, non-rotating front element
  • Accessories - Hood: Full-metal, rectangular, screw-mount hood (supplied with the lens)
  • Dimensions and weight
    • Length to bayonet flange - Approx. 46 /58 mm (with /without lens hood)
    • Largest diameter - Approx. 56 mm
    • Weight - Approx. 320 g
  • Data from - May 17, 2010 Leica press release
