Summicron (II) f= 9 cm 1:2
Revision as of 20:36, 15 January 2011 by Admin (talk | contribs)
  • Leica Order No. - 11123, 11132-head only, pre-set diaphram, 11133-head only LLC - 175
  • Production era - 1963-1976 < 5,430 lenses
  • Variants - Black and chrome, f/16, f/22, scalloped focusing knurl (SFK), and preset diaphragm in short mount (PDS) for use with Visoflex
  • Lens mount - Leica Screw-thread, M-bayonet and preset diaphragm in short mount for use with Visoflex
  • Number of lenses /groups -
  • F stop range - f/2-f/16 or f/22
  • Smallest object field -
  • Diaphragm setting /type - 12-blade
  • Angle of view diagonal - 27 degrees
  • Filter type - E49
  • Accessories - Visoflex adapter 16462; Bellows II adapter 16598; OUEPO 16474 Close focus ring.
  • Materials - Clear and black anodized aluminum
  • Dimensions length - 112 mm / 4.4 in
  • Weight - 685 g /1.51 lb
  • Inscriptions - Ernst Leitz Canada Summicron f-9cm 1:2 Nr.158xxxx
    LEITZ CANADA 168XXXX SUMMICRON 1:2 / 90
  • Designer - Walter Mandler
Summicron (II) f= 9 cm 1:2 Serial Numbers
.*Lens nos. 1745260 & 1745738 are 2/35 Summicron
^ Visoflex 9 cm 1:2 Summicron are in this batch
" Lens 2544666 in R-batch has M-bayonet
1983001 1983900 Summicron f= 9 cm 1:2 (SFK.M-chrom) 1963 900
2025001 2026000 Summicron f= 9 cm 1:2 (SFK.M-chrom) 1964 1000
2068501 2069500 Summicron f= 9 cm 1:2 (SFK.M-chrom) 1964 1000
2150551 2151550 Summicron f= 9 cm 1:2 (SFK-black) 1965 1000
2203101 2204100 Summicron f= 9 cm 1:2 (SFK.M-black) 1966 1000
2246051 2247150 Summicron f= 9 cm 1:2 (SFK.M-black) 1967 1100
2332801 2333800 Summicron f= 9 cm 1:2 1969 1000
2370801 2371800 Summicron f= 9 cm 1:2 (SFK.M-black) 1969 1000
2413101 2413600 Summicron f= 9 cm 1:2 (SFK.M-black) 1970 500
2499651 2500650 Summicron f= 9 cm 1:2 1971 1000
2544501" 2545700 Summicron-R" f= 9 cm 1:2 (M-black) 1972 [1200]
2623601 2624600 Summicron-M f= 9 cm 1:2 1973 1000
2659451 2660450 Summicron-M f= 9 cm 1:2 (M-black) 1973 1000
2731921 2731921 Summicron f= 9 cm 1:2 1974 1
2731922 2731950 Summicron f= 9 cm 1:2 1975 29
2751051 2752050 Summicron f= 9 cm 1:2 (M-black) 1975 1000
2770201 2771200 Summicron-M f= 9 cm 1:2 1976 1000
2791651 2792650 Summicron-M f= 9 cm 1:2 (M-black) 1976 1000
2813401 281800 Summicron-M f= 9 cm 1:2 1976 400
TOTAL ASSIGNED SERIAL NUMBERS 1963-1976 5,430
Lens superseded by 90mm f/2 Summicron-M III
