50mm f/2 Summicron-R I
Revision as of 12:23, 5 May 2011 by Admin (talk | contribs) (→50mm f/2 Summicron-R I Serial Numbers)
- Leica Order No. - 11 228-black LLC - 121
- Production era - 1964-1976 black; 1964-1966 200 chrome < 95,647 lenses
- Variants - 1-cam, 2-cam, 3-cam; black and chrome versions
- Note - The chrome finish was made for the Leicaflex. About 200 were made, and once it was found that the finish could reflect extraneous light in to the meter cell, this finish was discontinued in favor of black. chaos '06
- Number of lenses /groups - 6 / 5
- F stop range - f/2-f/16
- Closest focusing distance - 50 cm / 1.64 ft
- Smallest object field -
- Diaphragm setting /type - 6-blade
- Filter type - Series 6 + 14160
- Accessories - Hood: 12564 - Close focusing attachment: ELPRO - Filter ring: 14160
- Materials -
- Dimensions (length x diameter) - 38.5 x 63 mm / 1.52 x 2.48 in
- Weight - 680 g /1.50 lb
- Inscription - SUMMICRON-R 1:2/50 LEITZ CANADA (or WETZLAR) 2XXXXXX
- Designer - Walter Mandler
- On the street - €EU 780 chrome, 188 black, in 2008 - $US 175 in 2010
Serial numbers compiled from Puts Pocket Pod.* Lens 2359246 is Summicron 3.5 cm 1:2 (M-black.ELW)
1940501 | 1941000 | 50mm f/2 Summicron-R (1-cam.chrom) | 1962 | 500 |
1972001 | 1972100 | 50mm f/2 Summicron-R | 1963 | 100 |
1999001 | 1999998 | 50mm f/2 Summicron-R (2-cam.chrom) | 1963 | 998 |
2000002 | 2001000 | 50mm f/2 Summicron-R (1-cam.chrom) | 1963 | 999 |
2002001 | 2004000 | 50mm f/2 Summicron-R (1-cam.chrom) | 1963 | 2000 |
2033001 | 2034000 | 50mm f/2 Summicron-R | 1964 | 1000 |
2038701 | 2039700 | 50mm f/2 Summicron-R | 1964 | 1000 |
2078501 | 2080500 | 50mm f/2 Summicron-R | 1965 | 2000 |
2110801 | 2113800 | 50mm f/2 Summicron-R (1-cam.black) | 1965 | 3000 |
2134951 | 2136950 | 50mm f/2 Summicron-R | 1965 | 2000 |
2145451 | 2147450 | 50mm f/2 Summicron-R (1-cam.black) | 1965 | 2000 |
2157001 | 2159000 | 50mm f/2 Summicron-R | 1966 | 2000 |
2164501 | 2166500 | 50mm f/2 Summicron-R | 1966 | 2000 |
2173701 | 2175700 | 50mm f/2 Summicron-R | 1966 | 2000 |
2178901 | 2180900 | 50mm f/2 Summicron-R | 1966 | 2000 |
2190901 | 2192900 | 50mm f/2 Summicron-R (1-cam.black) | 1966 | 2000 |
2199101 | 2201100 | 50mm f/2 Summicron-R (2-cam.black) | 1966 | 2000 |
2204101 | 2206100 | 50mm f/2 Summicron-R (1-cam.chrom) | 1966 | 2000 |
2224001 | 2226000 | 50mm f/2 Summicron-R (1-cam.black) | 1967 | 2000 |
2229801 | 2231800 | 50mm f/2 Summicron-R (2-cam.black+chrom) | 1967 | 2000 |
2242051 | 2244050 | 50mm f/2 Summicron-R (2-cam.black) | 1967 | 2000 |
2255401 | 2257400 | 50mm f/2 Summicron-R (2-cam.black) | 1968 | 2000 |
2265251 | 2267250 | 50mm f/2 Summicron-R (2-cam.black) | 1968 | 2000 |
2270251 | 2274250 | 50mm f/2 Summicron-R (2-cam.black) | 1968 | 4000 |
2299951 | 2303950 | 50mm f/2 Summicron-R (2-cam.black) | 1968 | 4000 |
2320301 | 2324300 | 50mm f/2 Summicron-R (2-cam.black) | 1969 | 4000 |
2351301 | 2353300 | 50mm f/2 Summicron-R | 1969 | 2000 |
2358301* | 2360000 | 50mm f/2 Summicron-R | 1969 | 1700 |
2360001 | 2362000 | 50mm f/2 Summicron-R | 1969 | 2000 |
2366001 | 2368000 | 50mm f/2 Summicron-R | 1969 | 2000 |
2380701 | 2382700 | 50mm f/2 Summicron-R (2-cam.black) | 1969 | 2000 |
2388201 | 2390200 | 50mm f/2 Summicron-R (2-cam.black) | 1970 | 2000 |
2411101 | 2413100 | 50mm f/2 Summicron-R | 1970 | 2000 |
2422201 | 2424200 | 50mm f/2 Summicron-R (2-cam.black) | 1970 | 2000 |
2430751 | 2432750 | 50mm f/2 Summicron-R (2-cam.black) | 1970 | 2000 |
2435751 | 2437750 | 50mm f/2 Summicron-R | 1970 | 2000 |
2437751 | 2438000 | 50mm f/2 Summicron-R | 1970 | 250 |
2487201 | 2489200 | 50mm f/2 Summicron-R | 1971 | 2000 |
2501001 | 2503000 | 50mm f/2 Summicron-R | 1971 | 2000 |
2520401 | 2522400 | 50mm f/2 Summicron-R | 1972 | 2000 |
2527501 | 2529600 | 50mm f/2 Summicron-R | 1972 | 2100 |
2580551 | 2582550 | 50mm f/2 Summicron-R | 1973 | 2000 |
2588501 | 2590500 | 50mm f/2 Summicron-R (2-cam.black) | 1973 | 2000 |
2650601 | 2652600 | 50mm f/2 Summicron-R (2-cam.black) | 1973 | 2000 |
2665451 | 2667450 | 50mm f/2 Summicron-R | 1974 | 2000 |
2700601 | 2703600 | 50mm f/2 Summicron-R (2-cam.black+chrom) | 1974 | 3000 |
2715001 | 2718000 | 50mm f/2 Summicron-R (2-cam.black) | 1974 | 3000 |
2758151 | 2760150 | 50mm f/2 Summicron-R | 1975 | 2000 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1963-1975 | 95,647 |
Lens superseded by 50mm f/2 Summicron-R II
