135mm f/4 Tele-Elmar
Revision as of 18:28, 12 February 2012 by Admin (talk | contribs) (→135mm f/4 Tele-Elmar Serial Numbers)
- Leica Order No. - 11 851 (Tele-Elmar), 11 852 (lens head only), 11 861 (Tele-Elmar-M) LLC - 183
- Production era - 1965-1998 < 28,300 lenses
- Variants - Red scale (RS), yellow scale, scalloped (SFK) or unscalloped (UFK) focusing knurl, 1992-1998 telescoping hood version Tele-Elmar-M < 2,700 lenses
- Number of lenses /groups - 5 /3
- F stop range - f/4-f/22
- Closest focusing distance - 1.5 m /4.92 ft
- Smallest object field - 220 x 330 mm; 1:9
- Diaphragm setting /type -
- Filter type - E39, E46
- Accessories - Hood: IUFOO - 12575, or 12585 - The first 2 have removable heads used with Visoflex II & III with OTZFO + extension tube OTRPO or Bellows II
- Dimensions length x diameter - 112 x 59 mm / 4.41 x 2.32 in; 107 x 56 mm (tapered version 11 851) / 4.21 x 2.20 in
- Weight - 510 g / 1.12 lb (tapered version 11 851); 550 g /1.21 lb
- Inscriptions - TELE-ELMAR 1:4/135 LEITZ WETZLAR 2XXXXXX
TELE-ELMAR-M 1:4/135 LEITZ WETZLAR 3XXXXXX - Designer - Walter Mandler
- On the street - €EU 780 in 2007 (11 861) - $US 400 (E46) 275 (E39) in 2010
| 2046001 | 2047000 | 135mm f/4 Tele-Elmar (SFK+RS-11851) | 1964 | 1000 |
| 2082801 | 2084800 | 135mm f/4 Tele-Elmar (SFK+RS) | 1965 | 2000 |
| 2105801 | 2106800 | 135mm f/4 Tele-Elmar | 1965 | 1000 |
| 2143451 | 2145450 | 135mm f/4 Tele-Elmar | 1965 | 2000 |
| 2188901 | 2190900 | 135mm f/4 Tele-Elmar (SFK) | 1966 | 2000 |
| 2206101 | 2208100 | 135mm f/4 Tele-Elmar (SFK) | 1966 | 2000 |
| 2212501 | 2213000 | 135mm f/4 Tele-Elmar (SFK) | 1966 | 500 |
| 2231801 | 2233800 | 135mm f/4 Tele-Elmar (SFK) | 1967 | 2000 |
| 2382701 | 2384700 | 135mm f/4 Tele-Elmar (SFK) | 1969 | 2000 |
| 2420201 | 2422200 | 135mm f/4 Tele-Elmar (UFK) | 1970 | 2000 |
| 2458501 | 2459500 | 135mm f/4 Tele-Elmar | 1970 | 1000 |
| 2481101 | 2482200 | 135mm f/4 Tele-Elmar (UFK) | 1971 | 1100 |
| 2549551 | 2550550 | 135mm f/4 Tele-Elmar (UFK) | 1972 | 1000 |
| 2652601 | 2654600 | 135mm f/4 Tele-Elmar (UFK) | 1973 | 2000 |
| 2755351 | 2756350 | 135mm f/4 Tele-Elmar (UFK) | 1975 | 1000 |
| 2906801 | 2907800 | 135mm f/4 Tele-Elmar (UFK) | 1978 | 1000 |
| 3414891 | 3415890 | 135mm f/4 Tele-Elmar | 1986 | 1000 |
| 3469571 | 3470570 | 135mm f/4 Tele-Elmar | 1988 | 1000 |
| 3595960 | 3596459 | 135mm f/4 Tele-Elmar-M (UFK) | 1992 | 500 |
| 3621633 | 3621832 | 135mm f/4 Tele-Elmar-M | 1993 | 200 |
| 3634901 | 3635400 | 135mm f/4 Tele-Elmar-M | 1993 | 500 |
| 3658331 | 3658830 | 135mm f/4 Tele-Elmar-M (UFK) | 1994 | 500 |
| 3722803 | 3723802 | 135mm f/4 Tele-Elmar-M | 1995 | 1000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1964-1995 | 28,300 |
Lens superseded by 135mm f/3.4 ASPH Apo-Telyt-M
