D
Revision as of 17:38, 14 March 2012 by Admin (talk | contribs)
DACMO Replacement for core spools ? -
DACNO Replacement for core spools ? -
DAMCO Replacement spool ? -
DANCO Replacement spool for 120 film ? -
DAMOT NY Code for BINDOMAT 1949 -
DAMOX NY Code for BINDOMAT 1953 -
DAXOO Elmar f = 5 cm 1:3.5 - DAXOO ? -
DBOOF -
DBZOO -
DCBOO -
DCOOE -
DECIMAR Binoculars – 10 x 60 – 5.8 deg 1937-1959 -
DECIMARIT Binoculars – 10 x 60 – 5.8 deg – CF type 1937-1959 -
DEEMH Iris diaphram for Molna BEECH microscope lamp 1939 -
DEEML Bulb for Molna BEECH microscope lamp ? -
DEEMN Bulb for Molna BEECH microscope lamp ? -
DEEMO ? -
DEEMP Bulb for Molna BEECH microscope lamp ? -
DEEQK Lamp system for microscope side lighting -
DEFOO Spiral developing tank, 400 ml 1938 -
DEOOC Small CHICO flash, capacitor type, with ivory plastic housing 1954-1959 -
DEOOG Small CHICO flash, capacitor type, with black plastic housing ? -
DFHOO Small CHICO flash, capacitor type for Leica IIf and Leica IIIf 1954-1965 15608
DFOOB Flash bracket of ivory plastic 19??-19?? 15609
DFOOF Small CHICO flash, capacitor type for Leica IIf and Leica IIIf with cable ? -
DGKOO Flash cable to connect CHICO to other cameras ? 15612
DHMOO Ivory plastic box for CHICO ? -
DHLOO Plastic box, black, for CHICO ? -
DIOOY Diopter check wheel from -5 to +4 1955 -
DIREKT Self-timer Pierpaolo Ghisetti 1932 -
DIROM Self-timer 1935 -
DIRON Self-timer for periods of up to 10 ½ sec. 1936 New York version
DLUUW -
DMUOO Visoflex intermediate ring used to attach Summicron 50 mm to bellows or enlarger No. 17672 ? -
DNWOO M>L39 adapter ring for Focomat IIc -
DOBOR -
DOOCQ Focotar - 1 1:4.5 / 50 mm, adaptor for the Reprovit II - ROOXU 1952-1970 -
DOOHF Focotar - 2 1:4.5 / 50 mm 1953-1975 17581
DOOGS Elmar f = 5 cm 1:3.5 - DOOGS 1951-1953 -
DOOIT Enlarger lens Elmar f3.5 50mm replaced by the Focotar - 1 1:4.5 / 50 mm ?-1953 -
DOOLU Spirit Bubble Level -
DOORX Extension tube for Focotar; adapter to mount Paxette lenses on Valoy II enlarger Forum discussion 17585 17675
DOOLU/S Spirit level accessory shoe, in black, nickel or chrome 1929-1939 -
DQOOR Enlarger lens Focotar 1:4.5 / 60 mm 1956-1982
DOOSL 25” clamp bracket for micro stand SPMOO 1938 -
DOOUM Enlarger lens Elmar f = 5 cm 1:4.5 - DOOUM ?-1953
DRXOO Aluminum container for one cassette, and later, for 2 cassettes 1952 14010
DTEEO MONLA microscope lamp green filter 1930s -
DTEEP Green filter for photo purposes ? -
DUFAN Dufaycolor Type A 1936 NY item
DUFAS Dufaycolor Type C 1936 NY item
DUFAT Dufaycolor Type D 1936 NY item
DUFUZ Dufaycolor Type E 1936 NY item
DUFEN Dufaycolor for emphasis 1936 NY item
DUFEP Dufaycolor for Kodachrome 1936 NY item
DUFES Dufaycolor for Kodachrome professional conversion filter ? NY item
DUFEX Dufaycolor for flash Kodachrome ? NY item
DUFEZ Dufaycolor for Kodachrome, Skylight ? NY item
DUFTU Dufaycolor Type B for tungsten 1936 NY item
DUUER -
DUUNV -
DUUOI -
DUUPW -
DUUQK -
DUUVZ -
DUUXA Prado 150 projector with Dimaron 10 cm 1:2.8 lens 1948-ca.1967 -
DUUYO Prado 150 projector with Hektor 8.5 cm 1:2.5 lens 1948-ca.1967 -
DXOOK Rubberized shoulder strap 1960 14094
DXOOL Rubberized shoulder strap 1962 -
DXOOM Dark leather shoulder strap ? -
DXOON Calf leather shoulder strap with rubber top ? -
DYUUI Mirror for the "Leitz Betrachtungskasten" Projector Fontenelle archive 1937-?? -
DZUUH -
