A
Revision as of 15:06, 27 March 2012 by Admin (talk | contribs)
Leitz "Binoculars" data courtesy of Peter Abrahams
ABCOO Nickel cutting blade for film shaped end Fontenelle archive 1937 - used with ANZOO template - see ABLON
ABFOO Snap-shot Leica, never sold 1935 -
ABLON Film trimming template 1931-1964 Forum discussion
ABOOT Leica II (model D) = AIROO + Elmar (I) f= 5 cm 1:3.5 1934-1948 before 1934 LYKUP = LYKAN + ELMAR
ACEDU Micro Lens No. 2 for the micro-projection approach VIII projectors -
ACHOO Leica III (model F) black lacquer with Summar f= 5 cm 1:2 1933-1939 - see also ACOOS, AFOON
ACHOO CHROM Leica III (model F) chrome with Summar f= 5 cm 1:2 1933-1935 - see also ACOOS, AFOONCHROM
ACOOS Leica III (model F) black lacquer with Elmar (I) f= 5 cm 1:3.5 1933-1939 - see also ACHOO, AFOON
ACOOS CHROM Leica III (model F) chrome with Elmar (I) f= 5 cm 1:3.5 1933-1935 - see also ACHOO, AFOON CHROM
ACUBE Wide band UV filter set for micro-projector VIII -
AFLUU 18x24 sheet of glass with lower opening for AKTUU -
ADFIK Hood with filter holder engraved for 90, 127, 135 mm and 50 mm f/3.5 lenses 1949-19?? NY item
ADKOO Leica IIIa (model G) with Summar f= 5 cm 1:2 cm 1935-1948 LIOON in US Catalog
ADOOR Leica IIIa (model G) with Elmar (II) f= 5 cm 1:3.5 1935-1948 LEOOR in US Catalog
ADR50 Focotar enlarger 1:4.5/50 mm ? -
ADR65 Focotar enlarger 1:3.5/65 mm ? -
ADSUM Adapter for Summitar filter thread A 36 ? -
ADVOO Close up set for Leica IIIg - Forum discussion 1959 - also 16503
AFLOO Film Charger for Leica 250 ? -
AFLUN Changed version ? -
AFOOV Leica III (model F) black lacquer body 1933-39 - see also ACOOS, ACHOO
AFOOV CHROM Leica III (model F) chrome body 1933-35 - see also ACOOS, ACHOO
AFUUV Lower glass for AKTUU with 18x24mm opening -
AGIIU Adjustment ring for microscopes with a diameter of 32 mm ? -
AGITA Electric Tank / film development with DC ? -
AGOTU Electric Tank / film development with AC ? -
AGNOO Leica IIIa (model G) chrome body ? LUOOB in US Catalog
AGNOO-SW Leica IIIa (model G) black paint body ? -
AGNUU Slide changer with 24 x 36 mm film gate -
AGOTU Slide changer with 24 x 36 mm film gate for AC power -
AGRIF Hand film loader for cassettes Fontenelle archive ? -
AGULI Timer for tanks ? -
AHOOT Waist level viewfinder for 5cm use with a swivel mask for 2.8cm ca. 1935
AIROO Leica II (model D) black lacquer body 1934- LYKAN before 1934
AIROO CHROM Late version Leica II (model D) chrome body 1934 -
AIUUS Slider for 18x24 film strips, projector VIII -
AKGBMI Underwater housing for Leica IIIf If up and Summicron ca.1958 16910
AKGBSU Underwater Housing for Leica If llf or lllf ca.1958 16915
AKGRSU Underwater housing for Leica IIIf If up and Summitar ca.1958 16905
AKGRMI Underwater Housing for Leica If, IIf or IIIf ca.1958 16900
AKTOO High-power AKTINA Lamp for Focomat II enlarger ? -
AKTUU Film gate with semi-automatic film movement for 24x36mm Projector VIII ? -
AKUUR Slide changer with circular opening of 43 mm. diameter for 5x5 cm ? -
ALVOO Standard Leica (model E) black enameled, without spool chamber and without lens 1932-1948 - see also AROOG
ALVOO CHROM Standard Leica (model E) chrome body 1937 catalog
ALVUU Slide changer for 2x2 in glass slides ? -
AMPLIVID Binoculars - 6 x 24 - 12 deg 1956-1962 -
AMTOM Electric timer for bayonet cameras ? -
AMTOO Electric timer for screw cameras ? -
AMUUP 750 w projector lamp ca. 1937 - also AMUUP-E
AMXOO Leica IIIb with [[Xenon f= 5 cm 1:1.5] 1937 catalog
ANIIO -
ANUUO -
ANZOO Trimming template for Leica 250 (models DD, FF & GG) film 1937 - used with ABCOO blade
ANZUU -
APDOO Self-timer ca. 1938-1965 -
AQOOT Winding Knob Extension for screw mount cameras for repro work ? -
ARHOO Leica I (model C) with Elmar (I) f= 5 cm 1:3.5 1930-1933 1937 catalog
Aristophot Macrophotography optical bench, configured like a microscope, with a very long bellows instead of the microscope tube, and a camera at the head 1954-ca.1967 -
ARMST Stereo Prism Holder for Leica IIIb ? -
AROOG Standard Leica (model E) black lacquer body, with attached horizontal rangefinder 1932-1948 - see also ALVOO
AROOG CHROM Standard Leica (model E) chrome body, with attached horizontal rangefinder 1934-1935 - see also ALVOOCHROM
ASKOO APDOO self-timer with leather case ca. 1937 -
ASPUL Manual Hand Film Loader ? -
ASUUI -
ATMUU -
ATTAC -
ATOOH Leica IIIb chrome 1938-41 -
AUFSU Reflecting (waist level) viewfinder for 50mm lens JCB's...a little ca. 1932-1945 -
AUTAS Prism for Mikas microscope ? -
AUXWI -
AVIODIX Binoculars - 10 x 50 1919-1931 - military version 1917
AVIODIXIT Binoculars - 10 x 50 - 5 deg - CF type 1931 -
AVIOSEPT Binoculars - 7 x 50 - 7.3 deg 1919-1931 -
AVIOSEPTIT Binoculars - 7x50 - 7.3 deg - CF type 1930-1931 -
AVIOFORTE Binoculars - 12 x 60 - 4.3 deg 1919-1930 -
AVIONAR Binoculars - 15 x 60 ? -
AVOOF -
AVQUU -
AWOOE -
AWSUU -
AWUUE Slide changer with circular opening of 50 mm. diameter for Leica diapositives 3x4cm between 5x5cm glass plates pre 1937 -
AXUOO -
AYOOK Reflecting (waist level) viewfinder AUFSU / AHOOT for 35 + 50mm lens ? - also AYOOC
AYUUK Reflecting (waist level) viewfinder AYOOK with New York Engravings ? -
AYUUL Reflecting (waist level) viewfinder AHOOT with New York Engravings ? -
AYUUN Reflecting (waist level) viewfinder without the 2.8 cm swivel lens ? -
AYUUO Reflecting (waist level) viewfinder for 35 mm lens ? -
AZOOB Leica IIIb with Summar f= 5 cm 1:2 1937 catalog
AZUUB -
