C
Revision as of 23:10, 1 May 2012 by Admin (talk | contribs)
CABSO Focusing attachment with 2 shutters and holding collar for microscope eyepiece ? -
CABSU Focusing attachment with 1 shutter and holding collar for microscope eyepiece ? -
CAFAM Micro Camera Case for 9 x 12 cm plates ? -
CAFOT Micro Camera Case for 4.5 x 6 cm plates ? -
CALOS Shutter release for MIKAS 1939 -
Camcraft N-5 Motor drive for M1, M2 and MP 1958-? Lager, Vol. III, p. 67
CAMIAN Rewind crank for M1, M2, M3 and MP, chrome, USA version 1950-1960s Lager, Vol.III, p. 77
CAREU Used with LUCCA camera mount for stereo microscope, without magnification marker ? -
CAREX Used with LUCCA camera mount for stereo microscope, with magnification marker ? -
CARTY Self-timer 1932 Lager, Vol.III, p. 10c
CAVOO Flash unit similar to CEYOO with various AF settings 1951-1953 -
CAMPAR Binoculars – 10 x 40 – 7.3 deg 1932-1959 -
CAMPARIT Binoculars – 10 x 40 – 7.3 deg – CF type 1932-1959 -
CAMPOFORT Binoculars – 15 x 60 – 4.6 deg – IF type 1932-1962 -
CAMPOFORTIT Binoculars – 15 x 60 – 4.6 deg – CF type 1932-1962 -
CAMPOMAR Binoculars – 12 x 50 – 5.7 deg 1932-1949+ -
CAMPOMARIT Binoculars – 12 x 50 – 5.7 deg – CF type 1932-1949+ -
CANOE -
CARIR -
CARTY -
CASAU -
CBOOD Slip-in mask 18 x 24 mm for Focomat Model II, VYBOO and VYOOS pre 1937 -
CBUUD -
CDEOO Slip-in mask 24 x 36 mm for Focomat Model II, VYBOO and VYOOS pre 1937 -
CDOOB Slip-in mask 30 x 40 mm for Focomat Model II, VYBOO and VYOOS pre 1937 -
CENTO Light shield for VALOY enlarger pre 1937 -
CEYAL New code word for CEYOO-PARAL flash unit 1959 15506
CEYAT Flash device CEYAL without rectifier ? -
CEYOO Flash device with f-sync 1950-1959 -
CEYOT Flash device without f-sync ? -
CEYOO-PARAL Flash unit CEYOO for simultaneous triggering of multiple flash units 1952-1958 -
CFIOO Slip-in mask 40 x 40 mm for Focomat Model II, VYBOO and VYOOS pre 1937 -
CFOOZ Slip-in mask 40 x 65 mm for Focomat Model II, VYBOO and VYOOS pre 1937 -
CGLOO Slip-in mask 45 x 60 mm for Focomat Model II, VYBOO and VYOOS pre 1937 -
CGOOY Slip-in mask 60 x 60 mm for Focomat Model II, VYBOO and VYOOS pre 1937 -
CHICO Flash unit for Leica IIIf also known as DEOOC 1954-1959 -
CHNOO Slip-in mask 65 x 90 mm for Focomat model II pre 1937 -
CHOOX Slip-in mask 60 x 90 mm for Focomat model II pre 1937 -
CHROM Special filters in chrome, with 34 mm adapter for Wratten filter E 32 mm ? -
CHROM-WH Special filters for military use ? -
CINLE Adapter for Leica lenses on 16 mm cameras with C-Mount ? -
CINPY Adapter for Leica lenses on 16 mm cameras; for example Howell 70 mm cine cameras ? USA catalog
CKOOV Negative mask for 24 x 24 mm frame size Leica Catalog for 1955/58 p. 53
CLIPP Rangefinder -
CMEET-XCEES Copy stand with vertical and horizontal adjustment ? -
CMEET-XCEET Copy stand with vertical adjustment ? -
CMVOO Vacuum Synchronizer Dial "B" - speeds 20-1, 30, 40, 60, 100, 200, 500, 1000 for CAVOO, COOIF, etc. ? -
CNOOS Sync cable for CHICO flash unit except for M3, ? 15520
CNXOO Connector plug for double flash CEYOO ? 15538
CODRO Small Correx developing tank with "circulation" 1952-1955 -
CODRORF Correx film unit for 120 and 620 roll film ? -
COOAB Short Einstellschnecke for Hektor f= 7.3 cm 1:1.9 ? -
COOAS As above, but for Mountain Elmar ? -
COODQ Turning knob for CORUN Correx tank ? -
COODX Turning knob for CORUN Correx tank ? -
COOED Short Einstellschnecke for Elmar (I) f= 9 cm 1:4 Fontenelle archive ? see JCB Accessories
COOEL Adapter for Elmar (I) f= 9 cm 1:4 with COOMI ? -
COOFR Correx band 12 ft. long, molded on one side, for simultaneous development of two Leica films in CORUN tank pre 1937 -
COOHO Adapter for Hektor f= 13.5 cm 1:4.5 with COOMI ? -
COOHS Short Einstellschnecke for Hektor f= 13.5 cm 1:4.5 ? -
COOIF Spare Synch for vacuum or CAVOO with lightning and electrical cables ? -
COOIS As above, but with a different voltage ? -
COOKT Extension cable CNOOS or MOONZ for flash CEYOO ? 15543
COOLG Case for "Sports" viewfinder SAIOO, SEROO or SYEOO ? -
COOMI Verlängerungstubus with micrometer adjustment, adjustable, black / chrome ? -
COONS Sync cable for Leica M3, except for flash CHICO ? 15523
COONT Sync / CAVOO substitute for electrical and lightning ? -
COONY Adapter socket for Velostigmat 4.5 / 9 cm lens ? -
COOPI -
COOSE Adapter for Velostigmat 4.5 / 12.7 cm lens ? -
COOSD -
COOSX Sync cable for connecting CEYOO to external cameras ? 15522
COOTL Short mount for Thambar f= 9 cm 1:2.2 ? -
COOUY Replacement condenser for CEYOO, CAVOO or CEYAL ? -
COOWQ -
COOYA Case for SBOOI viewfinder JCB's a little...IIf
COPIN FocaSlide, calibrated glass strip focusing screen Forum discussion 1939- -
CORAX Double Correx band for CODRO 1950 -
CORBA Correx band with bracket for CORDO ? -
CORBAS As above, but for 120 roll film ? -
CORBAT As above, but for 620 film ? -
CORBAX ? -
CORBARF Replacement for 120/620 film Correx band, New York version ? -
CORCF Correx tank lid only ? -
CORDO Developing tank made of metal, 350 ml, complete with spool 1933-1939 -
CORDRF Replacement film spool 120 film ? -
CORET Small thermometer for Correx tank pre 1932 -
CORFR -
CORID Inner spool for Correx Tank pre 1932 -
CORIDCJ Replacement film spool ? -
CORLE Container with lid for CORDO ? -
COROL Correx tank, cover and knob pre 1932 -
COROS Correx tank, cover without knob ? -
CORPE -
CORREX Black Bakelite Developing Tank ca.1935 -
CORSO Replacement spool for CORDO ? -
CORSOL Replacement spool for CORDO, revised version ? -
CORSORF Replacement film spool ? -
CORSU Inner spool CORDO ? -
CORUN Large Correx tank with 500 ml capacity 1931-1955 -
CORUNT Large Correx tank with 500 ml capacity, revised version ? -
CORUNCJ Large Correx tank with 500 ml capacity, revised version ? -
CORYB Celluloid Correx band with clip and without bracket pre 1932 -
CORYBCJ -
CORYBCL Replacement celluloid Correx band ? -
COSIN FocaSlide, calibrated glass strip focusing screen ? -
COSLA Visoflex focusing stage, like FULET, with calibrated glass holder ? New York version
COSLAD Visoflex focusing stage ? -
COSTI Spool winding knob for Correx tank ? -
COSTID Spool winding knob for Correx tank ? -
CPBOO Case for SVGOO viewfinder ca.1951-1960 JCB's a little...IIf
CSOON Flash connection cable for CEYOO except for M3 ? -
CTKOO Flash connection cable for M3 to Braun-Hobby flash unit ? -
CTOOM Adjustable flash bracket, plastic, and later metal pre 1955 JCB's a little...19
CTOON Adjustable flash bracket, black painted metal ? -
CUMOO Connection piece for cable as part of CNOOS / MOONZ ? -
CUMOS Connection piece for cable as part of CNOOS / MOONZ ? -
CUMOT ? -
CUOOL Connecting sync cable for Leica cameras for CHICO flash unit except for M3 ca.1959 -
CUOOK Connecting sync cable for Leica cameras for CHICO flash unit except for M3 ca.1959 -
CVOOK CHICO flash unit with connecting sync cable for M3 1954-1959 -
CVOOX CHICO flash unit with connecting sync cable for M2 ca.1959 -
CVOOZ CHICO flash unit with connecting sync cable for M1 ca.1959 -
CWOOI -
CXOOH -
CXSOO -
CYOOG -
CYUOO -
CZOOF -
CZWOO -
