M-E
- Production era - 2012-Current
- Order no. -
- Serial nos. - -4420969-
- Camera type - Compact digital view, and rangefinder system, still camera.
- Materials - All-metal case made of die-cast magnesium; synthetic leather covering.
- Top Cover - Milled brass top cover with classic Leica M design, cap and base plate made of brass
- Available finish - anthracite grey paint
- Image Sensor - KAF - 18500 18 MP CCD Sensor
- Number of effective Pixels - 18 Million Pixels
- Sensitivity range - ISO 160 – ISO 2500, Pull 80 available, Auto ISO
- Imaging Platform - DSP based computing platform with Leica imaging algorithms
- LCD Monitor - 2.5 inch TFT Display with 230,000 Pixels
- Shutter - Closed type focal plane shutter for classic image exposure, with external cocking mechanics
- Shutter Speed - 1 /4000 s – 240 s (in Bulb), 1 /180 s flash synchronization
- Burst rate - approx. 2 fps
- Self timer - Off / 2 s / 12 s
- Storage Media - SD / SDHC Memory Cards
- Imaging functions
- Image File Format - DNG™ (RAW data uncompressed or nonlinear compressed), JPEG
- File Size: DNG - 18 MB (compressed) /36 MB (uncompressed), JPEG: Resolution and image content dependent
- Imaging functions
- Available JPG
- Resolutions - 5212 x 3472 (18 MP), 3840 x 2592 (10 MP), 2592 x 1728 (4.5 MP), 1728 x 1152 (2 MP), 1280 x 846 pixels (1 MP)
- Color Spaces - sRGB / Adobe®RGB
- White Balance - Auto / Daylight / Cloudy / Shade /Tungsten /Fluorescent 1 / Fluorescent 2 / Flash / Manual / Kelvin 2000 - 12800
- Other functions - Saturation, Contrast, Sharpening
- Exposure Control
- Exposure Metering - Through the Lens (TTL) metering, centerweighted with variable aperture
- Center-weighted TTL metering for flash exposure with system-conformant SCA - 3000 /2 standard flash units
- Exposure setting - Manual shutter speed setting with direct dial, A-Mode with direct dial
- Exposure Modes - Automatic shutter speed (A-Mode), Manual Exposure (M-Mode)
- Exposure
- Compensation . -3 EV to +3 EV, 1/3 f-stops
- Exposure Bracketing - 3 /5 /7 frames, 0.5 / 1 / 1.5 / 2 f-stops
- Flash exposure Control
- Flash exposure metering - Control with center-weighted TTL pre-flash metering (with SCA-3501/3502 adapter, or SCA-3000 standard flash unit such as Leica SF 24D /Leica SF-58).
- Hot shoe - SCA-3502 compatible hot shoe, with center contact
- Flash Synchronization - Optional triggered at first or second shutter curtain
- Flash Synch time - 1/180s
- Viewfinder / Focusing
- Focusing Methods - Manual focus with optical rangefinder
- Optical Viewfinder - Large, light bright-line rangefinder with automatic parallax compensation, optical illumination
- Optical Viewfinder frame lines - Framelines size matches image sensor size at 1m focusing distance
- Optical Viewfinder correction - Eyepiece adjusted to -0.5 dpt. Corrective lenses from -3 to +3 dpt. available (optional)
- Optical Viewfinder Magnification - 0.68x
- Optical Viewfinder Displays - In the viewfinder LED symbol for flash status (at bottom).
- Four-digit seven-segment LED digital display, brightness adapted to ambient conditions, for - warning in case of exposure correction - display of automatic shutter speed in automatic mode - advisory indicating use of metering memory lock.
- LED exposure monitor with two triangular and one central circular LED with manual exposure setting
- Rangefinder - Split or superimposed image range finder shown as a bright field in the center of the viewfinder image
- Rangefinder effective metering basis - 47.1 mm (mechanical metering basis 69.25 mm x viewfinder magnification 0.68 times)
- Other features
- Start up time - < 1s
- Power Supply - Li-ion battery (included), 3.7V, 1860 mAh
- User Profiles - 4 Profiles
- Sensor cleaning - Manual cleaning function
- Tripod Thread - A 1 /4 (1 /4") DIN made of stainless steel in base plate
- Dimensions (W x D x H) - approx. 139 x 37 x 80 mm (5.5 x 1.7 x 3.1 in)
- Weight - 585 g (20.6 oz)
- Operating Temperature - 0° C – 40° C
- Menu languages - English, German, French, Italian, Spanish, Russian, Japanese, Traditional Chinese, Simplified Chinese
- Accessories Included - Battery, Charger with power cables for EU and USA (different in some export markets), 12V charging cable, Carrying strap, Body cap
- Software licenses
- Supplied - Adobe® Lightroom®
- Optional accessories - All accessories that are made for the Leica M9 / M9-P
- Manufacturer's data as of September 2012
