Vario-Elmar-S 30-90mm f/3.5-5.6 ASPH.
Revision as of 17:22, 20 September 2012 by Admin (talk | contribs)
  • Order number - 11058
  • Production era - 2012-
  • Optical design
    • Lenses /groups - 14 /11
    • Image angle (diagonal, horizontal, vertical) - WA 81.5°, 71°, 51°, T 34°, 28.5°, 19.5°, corresponds to approx. WA 24 /T 72 mm focal length in 35 mm format
    • Position of entrance pupil - WA 72.8 mm /T 65.9 mm from apex of 1st lens element
  • Setting /function - Electronically controlled diaphragm, set using dial on camera, including half values
    • Aperture range - 3.5 to 32
    • Focusing range - 0.65 m to infinity
  • Distance setting
    • Smallest object field - 514 mm × 771 mm at 30 mm /194 mm × 291 mm at 90 mm
    • Largest reproduction ratio - 1 : 6.5
  • Size
    • Filter mount - Internal thread for E95 filter, filter mount does not rotate
    • Dimensions (diameter /length) - 101 mm /113.5 mm
    • Weight: 1275 g
  • Accessories included - Lens Hood : 12404 - Rear lens cover : 16020 - Lens cover S 16027
  • Serial nos. -
