Leica S
- Production era - 2012-Current
- Order nos. - 10 800 - S2 10 801 - S2-P 10 802
- Camera type - Digital medium-format single-lens reflex camera for use with Leica S lenses.
- Image sensor - low-noise CCD sensor with microlenses and microlens shift
- Resolution: 37.5 megapixels (7,500 x 5,000), size: 45 x 30 mm, pixel spacing: 6 μm. aspect ratio: 3:2, dynamic range: 12 stops, color depth: 16 bits per pixel, color spaces sRGB /Adobe RGB, /ECI RGB 2.0, low-pass filter - no, IR filter - on sensor, Moiré suppression - In external image processing software (e.g. with the Adobe® Lightroom® software provided with the camera)
- White balance - Presets - daylight, cloudy , shade, tungsten, HMI, fluorescent warm, fluorescent cool, flash /auto /manual set / color temperature (Kelvin)
- Sensitivity range - ISO 100 (pull 80) to 1600 (manual or automatic control).
- Lenses
- Lens mount - Leica S-Bayonet for Leica S-Lenses
- Focal length - Dependent on Leica S-Lens attached, conversion factor to 35 mm film equivalent 0.8 ×.
- Focusing
- Type - Predictive AF with center cross-sensor defined by cross-hairs on the focusing screen, focusing drive integrated in lenses
- AF modes - Selectable modes AF s (single) = focus priority, AF c (continuous) = release priority, MF (manual), manual override of AF settings possible at all times
- AF memory - Second resistance point hold on shutter release, lock for single exposure or constant by setting with 5-way control
- Manual focus - With lens focusing ring
- Exposure setting
- Exposure metering - Exposure metering through the lens (TTL), Metering modes - Multi-segment metering (5 fields), center-weighted integral metering, selective (spot) metering (3.5% of image frame).
- AE lock - Second resistance point hold on shutter release, lock for single exposure or constant by setting with 5-way control
- Metering range - (at f/2.5 and ISO 100) Spot metering: EV 2.7 – 20, center-weighted and multi-segment metering: EV 1.2 – 20, warning signal in viewfinder when out of metering range, multi-field photodiode metering cell for available light (continuous light metering)
- Exposure control - Programme AE (with shift function) (P), shutter priority AE (T), aperture priority AE (A), manual metering (M)
- Exposure compensation - compensation ± 3 EV in half-EV increments.
- Bracketing (AEB) - 3 /5 exposures (automatic /manual) / ½, 1, 2, 3 stops, depending on mode setting, variation of exposures with aperture or shutter speed
- ISO sensitivity - ISO 100, ISO 200, ISO 400, ISO 800, ISO1600, automatic control
- Shutter - Selectable with main switch
- Type - In-camera - Microprocessor-controlled, metal-blade, vertical focal-plane shutter
- Shutter speeds - Manual setting (T and M modes): 6s to 1 /4000 s in half-speed increments, time exposure (B mode): up to max. 125 s, flash sync speed 1 /125 s, automatic (A and P modes): continuous from 32 s to 1 /4000 s
- CS shutter option - Optional central shutter in Leica S-Lenses (CS versions).
- CS shutter speeds - Manual setting (T and M modes): 6s to 1 /1000 s in half-speed increments, flash sync at all speeds, automatic (A and P modes): continuous from 8 s to 1 /1000 s
- Linear flash mode - faster sync speeds than 1/125 s possible with Leica SF 58 flash unit and HSS-capable SCA 3002 flashes
- Continuous shooting - ~ 1.5 fps
- Release button - 3-step; activation of metering and AF functions, AE/AF lock, shutter release
- Self-timer - Selectable delay, 2 s or 12 s, activation signaled by flashing LED on front of camera and display on monitor
- Mirror pre-release - 1st release - Mirror flips up, locks in up position, aperture closes to selected value, 2nd release: Shutter releases, exposure, mirror returns
- Viewfinder
- Type - Pentaprism viewfinder with high-eyepoint eyepiece, LCD bar below viewfinder image, illuminated and with displays /warnings
- Magnification - 0.87 × (with 70 mm lens at infinity).
- Viewfinder coverage - ~ 98%
- Diopter compensation - –3 to +1 diopters
- Focusing screen - Interchangeable, ground glass screen with microprism ring and split image (standard), full ground glass screen with cross-hairs (optional accessory), full ground glass screen with engraved grid (optional accessory)
- Displays
- Type - Full-color, self-illuminating, top-deck panel (OLED), (OLED), monitor screen
- Monitor screen - 3-inch TFT-LCD monitor screen with 921,600 pixels, 16 million colors, sRGB color space, image field ~ 100%, maximum oblique viewing angle 170°
- Protective cover - Anti-reflex /dirt-repellent protective glass cover in scratch-resistant Corning®Gorilla®Glass
- Flash
- Connection - Hot shoe with central contact and dedicated control contacts, LEMO® or standard flash connection sockets with out control of flash power, standard flash sync socket
- Metering modes - TTL (multi-segment, selective, center-weighted)
- Compatibility - Full compatibility with Leica SF-58 and flash units with SCA3002 adapters.
- X synchronization - 1 /125 s (body FPS) / 1 /1000 s (lens CS), sync at all slower speeds, choice of first or second curtain sync; FPS flash sync at faster shutter speeds (1 /180 s - 1 /4000 s) possible with suitably equipped flash units (HSS mode)
- Flash exposure correction - ± 3 EV in ½ EV increments.
- Second curtain sync - Yes
- Flash metering cell - Multi-field photodiode
- Strobe flash mode - Automatic adjustment of shutter speed in exposure modes P and A
- Displays in flash mode - Flash-ready signaled by flashing /constant flash symbol in viewfinder
- Flash reflector angle - Automatic adaptation to focal length of lens attached with Leica SF-58 flash unit or system-compatible flash units with motorized zoom reflector
- Exposure modes - Single frame, continuous, self-timer 2 s (with mirror pre-release), self-timer 12 s (with mirror pre-release).
- Data recording
- Image file formats - DNG 5000 × 7500 pixels, 37.5 MP, ~ 72 MB per image, lossless compressed DNG (7500 × 5000 pixels, ~ 42 MB per image), JPEG (7500 × 5000 pixels, in three resolutions, 37.5, 9.3, 2.3 megapixels, ~ 1-16 MB per image, depending on resolution and image content).
- Maximum frame rate - 1.5 fps.
- Buffer memory - DNG max. 28 images, DNG compressed max. 32 images, JPEG no limit.
- Simultaneous recording in DNG and JPG possible - Yes, arbitrary combinations of DNG and JPEG, various formats on different memory cards (e.g. DNG on CF card, JPEG on SD card).
- Storage options - SD card (SD cards to 2 GB max., SDHC card to 32 GB max., SDXC card), CompactFlash card (UDMA7), external transfer to PC hard disk
- Other functions
- Review formats - Single frame with exposure parameters, single frame, 4 thumbnails, 9 thumbnails, loupe function.
- Zoom magnifier in review mode - 4-step loupe function , pixel-level magnification, 100% view by longer pressure on clickwheel.
- Delete protection - Delete protect for individual images.
- Menu categories - Camera, Image, Setup, Play.
- Menu languages - 9 languages: English, German, French, Italian, Spanish, Russian, Japanese, traditional Chinese, simplified Chinese.
- Firmware update - User upload option.
- GPS - Selectable (may not be available in all countries due to local legislation) – forced deactivation possible, positioning data recorded in the Exif data of image files
- Date /time - User setting option, automatic date-, time- and time zone-synchronization with activated GPS module
- Levelling - Acceleration-sensor controlled determination, range - Pitch (lateral axis) and tilt (longitudinal axis) ± 90°, accuracy / display sensitivity < 1° at 0-40°C (32 - 104°F) ambient temperature, displayed on monitor
- Interfaces
- PC - ISO hot shoe, High-speed USB 2.0 (LEMO socket with strain relief, cable included in package).
- Other - HDMI Type C socket, remote release, X-flash sync, SCA3002, 7-pin LEMO flash connection socket, interface for Leica multifunctional Handgrip S
- OS compatibility Systems - Windows® XP, Windows Vista®, Windows 7® Apple Macintosh upwards from MAC OSX® 10.5
- Software
- Software package - Adobe® Photoshop® Lightroom® and Leica Image Shuttle 2, downloadable from the Leica Owners Area after product registration.
- Power supply
- On /off - Main switch on top deck, selectable automatic sleep mode after ~ 2, 5, or 10 minutes
- Battery - Rechargeable lithium-ion battery, nominal voltage 7.4 V, capacity 2100 mAh.
- Battery-independent power supply - With Leica AC-Adapter S (optional accessory)
- Battery level display - in top deck OLED panel
- Power-saving options (sleep function) - 4 steps, 2 min, 5 min, 10 min, off
- Power supply and battery charger - Rapid charger S (with integrated US mains plug, interchangeable EU, UK, and AUS plugs, and car adapter) Inputs - 100–240 V AC, 50 /60 Hz, automatic adaptation, or 12 /24 V DC; output: 7.4 V DC, 1250 mA.
- Body
- Body construction - Full-metal chassis in diecast aluminum with high-grip plastic coating, magnesium alloy top deck, baseplate in glass-fiber reinforced polycarbonate
- Operating conditions - 0 to +45°C (32 to 113°F), 15–80% relative humidity.
- Dimensions (W × H × D) - 160 × 80 × 120 mm (6.29 x 4.72 x 3.15 in)
- Weight - ~ 1260 g / 2.78 lbs (body only, with battery).
- Dust proof/splash proof - Yes / yes.
- Tripod thread - 1 /4-inch and 3 /8-inch bushes, with locater holes for anti-twist locking pins.
- Package - S-Body, rapid charger S (with integrated US mains plug, interchangeable EU, UK, and AUS plugs, and car adapter), rechargeable lithium-ion battery, LEMO® USB cable, LEMO® flash sync cable, carrying strap, bayonet cap, eyepiece cap
- Accessories
- 14488 - SF-58 - Flash Unit
- 14491 - HDMI Kable S
- 16000 - Standard focusing screen S
- 16001 - Microprism focusing screen S
- 16002 - Grid focusing screen S, showing the “golden ratio” for precise image composition
- 16003 - Multifunctional Handgrip S (shown)
- 16004 - Hand strap (shown)
- 16010 - Case S
- 16011 - Professional charger S - 14429 Replacement battery S
- 16012 - Shutter Release Cable S
- Lens adapters
- Other - "High-quality filters can be obtained . . . from traditional manufacturers like B+W and Heliopan."
- Service packages - Leica Protection Plan Body (included in price) - Leica Protection Plan Lens (optional) - Leica Protection Plan Vario Lens (optional) - Leica Protection Plan CS Lens (optional)
- Manufacturer's data as of September 2012
- S Firmware Updates - (see Owner's Area for latest firmware)
| S2 Lenses |
