S2
Revision as of 15:11, 19 October 2012 by Admin (talk | contribs)
  • Production era - 2009-2012
  • Order nos. - 10 801 - S2-P 10 802
  • Camera type - Digital single-lens reflex camera for use with Leica S lenses.
  • Image sensor - low-noise Kodak CCD sensor, resolution - 37.5 megapixels (7,500 x 5,000), size - 45 x 30mm, pixel spacing - 6μm. aspect ratio: 3:2, dynamic range - 12 stops, color depth - 16 bits per pixel, low-pass filter - none (Moiré detection and suppression using digital signal processing).
  • Sensitivity range - ISO 80 to 1250 (manual or automatic control).
  • Data storage - Format - DNG (approx. 75 MB per image), JPEG (basic or fine), memory cards - CompactFlash (up to 64 GB), SD (HC).
  • Maximum frame rate - 1.5 images/s, buffer memory: 1 GB (for a minimum sequence of 8 images in DNG format).
  • Control monitor - 3-inch TFT with 460,000 pixels, 16 million colors, cover glass: highly abrasion and scratch resistant sapphire glass (only with the LEICA S2-P).
  • Connections - High-speed USB 2.0 (robust connection with strain-relief, cable included), HDMI, remote release, X sync, SCA3002.
  • Exposure metering - Multi-field metering (5 fields), center-weighted integral metering, spot metering (3.5%).
  • Exposure control - Program mode (with Shift function), shutter priority, aperture priority, manual metering.
  • Shutter - Metal focal-plane shutter integrated in body - 1 /4000 s to 32 s (B to 120 s), flash sync time - 1 /125 s, optional leaf shutter in selected lenses - 1 /500 s to 8 s, flash synch time - 1 /500 s.
  • Flash operation - Metering method - TTL (multi-field, selective, center-weighted), TTL-HSS rapid synchronization up to 1 /4000 s with shutter, Compatibility - fully compatible with LEICA SF-58 and devices with SCA3002 adapters.
  • Auto Focus - central crosshair sensor, focusing drive in lens, operating modes - AF continuous, AF single, MF, MF override, AF memory with AF lock button.
  • Viewfinder - High eye-point pentaprism viewfinder, magnification - 0.86 x, viewfinder field - 96%, diopter compensation -3 to +1, focusing screen - matte with cross-hairs (interchangeable).
  • Power supply - Li-Ion Akku (7.4 V, 2150 mAh)
  • Housing - Die-cast magnesium, size (without lens) - 160 x 120 x 80 mm /6.29 x 4.72 x 3.15 in, weight: 1410 g /49.73 oz (including battery), resistant to dust and dripping /splashing water.
  • Scope of supply - Software: Adobe Lightroom, Leica Image Shuttle, battery, charging unit, USB cable, carrying strap.
  • Accessories
    • 14488 - SF-58 - Flash Unit
    • 14491 - HDMI Cable S
    • 16000 - Standard focusing screen
    • 16001 - Microprism focusing screen
    • 16002 - Grid focusing screen, showing the “golden ratio” for precise image composition
    • 16003 - Multifunctional grip S
    • 16004 - Neoprene hand strap
    • 16010 - Case S
    • 16011 - Professional charger S - 14429 Battery
    • 16012 - S-Camera Remote Release Cable
    • Lens adapters
      • 16024 - S-Adapter V - Hasselblad V system lenses (introduced August 2011)
      • 16025 - S-Adapter P67 - Pentax 67 system lenses (introduced August 2011)
      • 16026 - S-Adapter M645 - Mamiya 645 system lenses (introduced August 2011)
      • 16030 - S-Adapter H - Hasselblad H system lenses (introduced May 2012)
    • Other - "High-quality filters can be obtained . . . from traditional manufacturers like B+W and Heliopan."
  • Designer - Manfred Meinzer (housing 09 Sep 2008 EU)
  • Manuals & brochures - Manufacturer's Site
  • S Lenses
  • S2 Firmware Updates - (see Owner's Area for latest firmware)
Leica S2 Serial Numbers
Serial numbers compiled from known S2 cameras
-3032249 unknown- Leica S2 2009 unknown
-unknown 3799028- Leica S2 2009 unknown
-3800217 3800971- Leica S2 2010 755+
-3832051 3833130- Leica S2 2011 1080+
-3905443 3905638- Leica S2 2011 196+
TOTAL ASSIGNED SERIAL NUMBERS 2009-2012 unknown
