P
PAMOO | Right angle 5x eyepiece; early version with mirror; later with prism; PAMOO + PROON = ODULO later used on Visoflex I | 1940-1962 | JCB's a little...If |
PBOOC | Light-tight wooden box Fontenelle archive | 1930s | - |
PCOOB | Yellow filter no. 0 very light; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
PEGOO | Visoflex I, 45 degree 4x eyepiece; black with rubber eyepiece JCB's a little...If Fontenelle archive | 1951-1962 | 16487 |
PEOOZ | Yellow filter no. 1 light; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
PFOOY | Yellow filter no. 2 medium; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
PHOTAR | Micro lens system for close-up work. See PHOTAR-ADAPTER-R | 1930s-2009 | - |
PGOOX | Graduated yellow filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
PGYOO | Graduated green filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
PHOOW | UVa filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
PIOOV | Panchromatic filter no. 1 ; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
PKOOU | Infra-red filter no. 1; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
PLGOO | Orange filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
PLOOT | Mirror reflex housing with flared eyepiece and double cable release | 1935-1951 | JCB's a little...11 |
PMOOS | Infra-red filter no. 2; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
PNOOR | Infra-red filter no. 3; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
POFLA | Kodachrome flash filter; screw-on type E48 | ca.1949 | NY item |
POLAR | Stereo transparency equipment to add to Leitz VII projector for viewing stereo projections | 1938-19?? | NY item |
POOAH | Yellow filter no. 0 very light; screw-on type E48 | ca.1935 | 13290 |
POOAY | Kodachrome filter type A; screw-on type E48 | ca.1949 | NY item |
POOBV | Yellow filter no. 1 light; screw-on type E48 | ca.1935 | 13295 |
POOCI | Yellow filter no. 2 medium; screw-on type E48 | ca.1935 | - |
POOCQ | Blue filter; screw-on type E48 | ca.1955 | 13307 |
POODW | Panchromatic filter no. 1; screw-on type E48 | ca.1935 | 13305 |
POOEK | Infra-red filter no. 2; screw-on type E48 | ca.1935 | - |
POOEL | Polarising filter; graduated, slip-on type A36 Pier Paolo Ghisetti | ca.1939 | 13350 |
POOFX | UVa filter; screw-on type E48 | ca.1935 | 13330 |
POOGL | Infra-red filter no. 1; screw-on type E48 | ca.1935 | 13315 |
POOHY | Infra-red filter no. 3; screw-on type E48 | ca.1935 | 13325 |
POOIM | Chimney 5x flared eyepiece with swing-in 30x magnifier for PLOOT | 1935-1951 | - |
POOKZ | Orange filter; screw-on type E48 | ca.1935 | 13310 |
POOLN | Polarising filter; swing-out, slip-on type A36 with clamping screw | ca.1939 | - |
POORE | Polarising filter; graduated, screw-on type L for Summitar f= 5 cm 1:2 | ca.1949 | 13362 |
POORQ | Double cable release for PLOOT mirror reflex housing | 1936-19?? | - |
POOTR | Polarising filter; graduated, screw-in mount E39 | ca.1939 | 13362 |
POSKY | Kodachrome skylight filter; screw-on type E48 | ca.1949 | NY item |
PRADO | Leica projector series - see Leicawiki.DE [1] | 1946-1984 | - |
Prismor | Close-focus addaptor for Leica IIIc and IIc equiped with the 5 cm Elmar (36 mm front ring diameter) Fontenelle archive | 1950- | - |
PROON | Pre Visoflex mirror reflex housing; used with PAMOO = ODULO; used with POOIM = PLOOT | 1940-1950 | - |
