P
Revision as of 14:12, 27 October 2012 by Admin (talk | contribs)
PAMOO Ploot right angle 5x eyepiece; early version with mirror; later with prism; PAMOO + PROON = ODULO later used on Visoflex I 1940-1962 JCB's a little...If
PBOOC Light-tight wooden box Fontenelle archive 1930s -
PCOOB Yellow filter no. 0 very light; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt ca.1935 -
PEGOO Visoflex I 45 degree 4x eyepiece; black with rubber eyepiece JCB's a little...If Fontenelle archive 1951-1962 16487
PEOOZ Yellow filter no. 1 light; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt ca.1935 -
PFOOY Yellow filter no. 2 medium; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt ca.1935 -
PHOTAR Micro lens system for close-up work. See PHOTAR-ADAPTER-R 1930s-2009 -
PGOOX Graduated yellow filter; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt ca.1935 -
PGYOO Graduated green filter; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt ca.1935 -
PHOOW UVa filter; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt ca.1935 -
PIOOV Panchromatic filter no. 1 ; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt ca.1935 -
PKOOU Infra-red filter no. 1; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt ca.1935 -
PLGOO Orange filter; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt ca.1935 -
PLOOT Mirror reflex housing with flared eyepiece and double cable release 1935-1951 JCB's a little...11
PMOOS Infra-red filter no. 2; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt ca.1935 -
PNOOR Infra-red filter no. 3; slip-on type D for Thambar f= 9 cm 1:2.2 and F = 20 cm 1:4 Telyt ca.1935 -
POFLA Kodachrome flash filter; screw-on type E48 ca.1949 NY item
POLAR Stereo transparency equipment to add to Leitz VII projector for viewing stereo projections 1938-19?? NY item
POOAH Yellow filter no. 0 very light; screw-on type E48 ca.1935 13290
POOAY Kodachrome filter type A; screw-on type E48 ca.1949 NY item
POOBV Yellow filter no. 1 light; screw-on type E48 ca.1935 13295
POOCI Yellow filter no. 2 medium; screw-on type E48 ca.1935 -
POOCQ Blue filter; screw-on type E48 ca.1955 13307
POODW Panchromatic filter no. 1; screw-on type E48 ca.1935 13305
POOEK Infra-red filter no. 2; screw-on type E48 ca.1935 -
POOEL Polarising filter; graduated, slip-on type A36 Pier Paolo Ghisetti ca.1939 13350
POOFX UVa filter; screw-on type E48 ca.1935 13330
POOGL Infra-red filter no. 1; screw-on type E48 ca.1935 13315
POOHY Infra-red filter no. 3; screw-on type E48 ca.1935 13325
POOIM Chimney 5x flared eyepiece with swing-in 30x magnifier for Ploot 1935-1951 -
POOKZ Orange filter; screw-on type E48 ca.1935 13310
POOLN Polarising filter; swing-out, slip-on type A36 with clamping screw ca.1939 -
POORE Polarising filter; graduated, screw-on type L for Summitar f= 5 cm 1:2 ca.1949 13362
POORQ Double cable release for Ploot mirror reflex housing 1936-19?? -
POOTR Polarising filter; graduated, screw-in mount E39 ca.1939 13362
POSKY Kodachrome skylight filter; screw-on type E48 ca.1949 NY item
PRADO
Pradovit
Leica slide projector (series) - see Leicawiki.DE [1] 1946-1984 -
Prismor Close-focus addaptor for Leica IIIc and IIc equiped with the 5 cm Elmar (36 mm front ring diameter) Fontenelle archive 1950- -
PROON Ploot mirror reflex housing; used with PAMOO = ODULO; used with POOIM = PLOOT 1940-1950 -
