Summarit f= 5 cm 1:1.5
  • Leica Order No. - SOOIA, SOOIA-M 11 120 LLC - 124
  • Production era - 1949-1960 < 74,643 lenses
  • Variants - Wetzlar, ELC and Taylor-Hobson versions (see Forum Discussion [7] #18 & [14 + 15] permalink below)
  • F stop range - f/1.5-f/16
  • Closest focusing distance -
  • Smallest object field -
  • Diaphragm setting /type - 16-blade
  • Type - One of the very few lenses that can be used for UV photography - see Forum Discussion [1] #11 permalink (and following) below
  • Filter type - A43 or E41
  • Accessories - Hood: XOONS 12150; Viewfinders: VIOOH and SBOOI 12015
  • Materials -
  • Weight - 320 g /11.29 oz
  • Inscription - Summarit f=5cm 1:1.5 Nr82XXXX Ernst Leitz GmbH Wetzlar
  • Designer - Otto Zimmermann
  • On the street - $US 260 (S) - 375 (M) in 2010
Summarit f= 5 cm 1:1.5 Serial Numbers
.* Lens 1290589 Summarit f= 5 cm 1:1.5 (ELC.S)
491898 492000 Summarit f= 5 cm 1:1.5 1939 103
740001 741000 Summarit f= 5 cm 1:1.5 1949 1000
801001 802000 Summarit f= 5 cm 1:1.5 1950 1000
820001 823000 Summarit f= 5 cm 1:1.5 (ELW.S+TH) 1950 3000
890001 893000 Summarit f= 5 cm 1:1.5 (ELW.S) 1951 3000
950001 955000 Summarit f= 5 cm 1:1.5 (ELW.S) 1952 5000
956001 956500 Summarit f= 5 cm 1:1.5 1952 500
987101 987150 Summarit f= 5 cm 1:1.5 1952 50
999001 1000000 Summarit f= 5 cm 1:1.5 (ELW.S) 1952 1000
1025001 1029500 Summarit f= 5 cm 1:1.5 (ELW.S) 1952 4500
1052001 1054000 Summarit f= 5 cm 1:1.5 (ELW.M) 1953 2000
1054201 1058000 Summarit f= 5 cm 1:1.5 (ELW.S) 1953 3800
1078001 1080000 Summarit f= 5 cm 1:1.5 (ELW.S) 1953 2000
1098001 1100000 Summarit f= 5 cm 1:1.5 (ELW.S+M) 1953 2000
1119201 1121000 Summarit f= 5 cm 1:1.5 (ELW.M) 1953 1800
1171501 1172500 Summarit f= 5 cm 1:1.5 1954 1000
1187001 1188000 Summarit f= 5 cm 1:1.5 1954 1000
1209001 1212000 Summarit f= 5 cm 1:1.5 (ELW.M+S) 1954 3000
1246001 1247000 Summarit f= 5 cm 1:1.5 (ELC.S) 1955 1000
1275001 1277000 Summarit f= 5 cm 1:1.5 (ELW.M) 1955 2000
1288001 *1291000 *Summaron f= 3.5 cm 1:3.5 1955 [3000]
1297001 1300000 Summarit f= 5 cm 1:1.5 (ELW.M) 1955 3000
1330001 1333000 Summarit f= 5 cm 1:1.5 (ELW.M) 1955 3000
1357001 1360000 Summarit f= 5 cm 1:1.5 (ELW.S+M) 1956 3000
1367501 1368500 Summarit f= 5 cm 1:1.5 1956 1000
1389001 1393000 Summarit f= 5 cm 1:1.5 (ELW.M) 1956 4000
1418001 1421000 Summarit f= 5 cm 1:1.5 (ELW+ELC.M) 1956 3000
1430001 1435000 Summarit f= 5 cm 1:1.5 (ELW.S+M) 1956 5000
1470001 1473000 Summarit f= 5 cm 1:1.5 (ELW.S) 1957 3000
1499001 1501000 Summarit f= 5 cm 1:1.5 (ELW.S+M) 1957 2000
1515001 1518000 Summarit f= 5 cm 1:1.5 (ELW.S) 1957 3000
1526001 1526900 Summarit f= 5 cm 1:1.5 1957 900
1527161 1530000 Summarit f= 5 cm 1:1.5 1957 2840
1535001 1537000 Summarit f= 5 cm 1:1.5 1957 2000
1546001 1546150 Summarit f= 5 cm 1:1.5 1957 150
TOTAL ASSIGNED SERIAL NUMBERS 1939-1957 74,643
