Super-Elmar-S 24mm f/3.5 ASPH.
- Order number - 11054
- Production era - 2012-
- Optical design
- Lenses /groups - 12 /10
- Image angle (diagonal, horizontal, vertical) - 96.6°, 86.5°, 63.9°, corresponds to approx. 19 mm focal length in 35 mm format
- Position of entrance pupil - 83.4 mm from apex of 1st lens element
- Setting /function - Electronically controlled diaphragm, set using dial on camera, including half values
- Aperture range - 3.5 to 22
- Focusing range - 0.4 m to infinity
- Distance setting
- Smallest object field - 349 mm × 533 mm
- Largest reproduction ratio - 1 : 11.3
- Size
- Filter mount - Internal thread for E95 filter, filter mount does not rotate
- Dimensions (diameter /length) - 101 mm /112 mm
- Weight: 1260 g
- Accessories included - Lens Hood : 12404 - Rear lens cover : 16020 - Lens cover S 16027
Super-Elmar-S 24mm f/3.5 ASPH Serial Numbers
Serial numbers compiled from known Super-Elmar-S 24mm f/3.5 ASPH lenses| SN Start | SN End | Product | Year | Total |
| -4152523 | 4152535- | Super-Elmar-S 24mm f/3.5 ASPH | 2012 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2012-Current | unknown |
