50mm f/2.8 Elmar-M
- Leica Order No. - 11 831-black - 11 823-silver LLC - 115
- Production era - 1994-2007 < 17,461 lenses
- Variants - Black / Chrome
- Compatibility - M-cameras except cannot be collapsed into the M5 or CL. Mount or remove collapsible 50mm Elmar lenses, of any vintage, extended only (per Forum discussion 20 below).
- Number of lenses/groups - 4 /3
- Focusing range - 0.7 m / 2.3 ft < ∞
- Aperture - f/2.8-f/16 - Setting/Function Preset, with click-stops, half values from f/2.8 - f/8, manual 6 blade diaphragm
- Smallest object field/Largest reproduction ratio - 274 mm x 411 mm / 1:11.4
- Angle of view (diagonal, horizontal, vertical) - 47°, 40°, 27°
- Position of entrance pupil - 17.1 mm (related to the first lens surface in light direction)
- Filter mount/Lens hood - Internal thread for screw-in filters size E39 / separate, clip-on type, lockable
- Materials - Black anodized aluminum or silver lacquered brass
- Focal length - 51.7 mm / 2 in
- Length to bayonet flange - 21.6 < 37.6 mm / 0.8" < 1.5 in
- Largest diameter - 52 mm / 2.1 in
- Weight - approx. 170 g / 6 oz anodized, 245 g / 8.6 oz silver lacquer
- Inscriptions - LEICA ELMAR-M 1:2.8/50 E39 3XXXXXX
- Ernst Leitz GmbH Wetzlar Elmar 1 = 5 cm 1:2,8 Nr. 1XXXXXX
- On the street - $US 1,095 in 2008 - 500 in 2010
50mm f/2.8 Elmar-M Serial Numbers
| 1975-0001 | 1975-1975 | 50mm f/2.8 Elmar-M (silb) | 1994 | 1975 |
| 3668031 | 3669030 | 50mm f/2.8 Elmar-M (silb) | 1994 | 1000 |
| 3691931 | 3692930 | 50mm f/2.8 Elmar-M (silb) | 1995 | 1000 |
| 3701552 | 3702551 | 50mm f/2.8 Elmar-M (silb+schw) | 1995 | 1000 |
| 3723803 | 3724802 | 50mm f/2.8 Elmar-M (silb+schw) | 1995 | 1000 |
| 3726554 | 3727553 | 50mm f/2.8 Elmar-M (silb) | 1995 | 1000 |
| 3732301 | 3733300 | 50mm f/2.8 Elmar-M (silb) | 1996 | 1000 |
| 3738701 | 3739700 | 50mm f/2.8 Elmar-M (silb) | 1996 | 1000 |
| 3741300 | 3741588 | 50mm f/2.8 Elmar-M | 1996 | 289 |
| 3761000 | 3761999 | 50mm f/2.8 Elmar-M (schw) | 1996 | 1000 |
| 3781330 | 3782329 | 50mm f/2.8 Elmar-M (silb+schw) | 1997 | 1000 |
| 3876167 | 3877166 | 50mm f/2.8 Elmar-M (schw) | 1999 | 1000 |
| 3897576 | 3898575 | 50mm f/2.8 Elmar schw. | 2000 | 1000 |
| 3911126 | 3912125 | 50mm f/2.8 Elmar schw. | 2000 | 1000 |
| 3917273 | 3918270 | 50mm f/2.8 Elmar schw. (+silb) | 2001 | 998 |
| 3919001 | 3919100 | 50mm f/2.8 Elmar silb. | 2001 | 100 |
| 3935764 | 3936763 | 50mm f/2.8 Elmar schw. | 2002 | 1000 |
| 3963511 | 3964510 | 50mm f/2.8 Elmar schw. (+ silb) | 2003 | 100 |
| 3980589 | 3981088 | 50mm f/2.8 Elmar schw. (+ silb) | 2004 | 499 |
| 3993121 | 3993620 | 50mm f/2.8 Elmar schw.u. Hc. (+ silb) | 2005 | 500 |
| unknown | unknown | 50mm f/2.8 Elmar | 2006-2007 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1994-2005 | 17,461 |
