C 112
- Order nos.
- Light-gold - 18 484 (E-version), 18 485 (U-version), 18 486 (TK-version), 18 487 (CN-version).
- Dark-red - 18 488 (E-version), 18 489 (U-version), 18 490 (TK-version), 18 491 (CN-version).
- Lens
- DC Vario-Summicron f/2-5.9 (at maximum wideangle and telephoto settings)/6-42.8 mm ASPH. (35 mm camera equivalent: 28–200 mm).
- Sensor
- 1 /1.7" MOS sensor. Primary color filter.
- Total pixel number - 12,800.000. Effective pixels: 12,100.000.
- Minimum illuminance - Approx. 6 lx.
- With camera models 18 484/-487/-488/-491: (when i-low light and 1/25 s shutter speed is used).
- With camera models 18 485/-486/-489/-490: (when i-low light and 1/30 s shutter speed is used).
- Focus range
- P/A/S/M - 50 cm /20 in - 80 cm /31.5 in (at maximum wideangle /telephoto settings) to inf.
- Macro/Snapshot modes/Video recording - 3 cm/1.2 in / 80 cm/31.5 in (at maximum wideangle /telephoto settings) to inf.
- Scene modes - May differ from the ranges above.
- Digital zoom - Max. 4 x.
- Stabilization system - Optical.
- Shutter system - Electronically and mechanically controlled.
- Shutter speed - 250 s to 1 /4000 s.
- (Starry Sky) Mode: 15 s, 30 s, 60 s.
- Exposure modes - Program mode (P), Aperture priority (A), Shutter speed priority (S), Manual setting (M),
- Exposure compensation - increments 1 /3 EV steps, setting range: ± 2 EV.
- Metering modes - Multiple, Center-weighted, Spot.
- Flash - Built-in.
- Flash modes - Auto , Auto /Red eye reduction, Slow sync./Red eye reduction, ON, OFF.
- Flash range - (with ISO auto )
- Approx. - 0, 6–7 m - 23–275 in (with maximum wide angle setting)
- Approx. - 0, 8–2, 3 m - 31–90 in (with maximum telephoto setting).
- Monitor - 3.0 in TFT-LCD with approx. 921,600 pixel.
- Aspect ratio - 3:2. Shows approx 100 % of the captured frame.
- Viewfinder - Color LCD with approx 200,000 pixel. Diopter correction facility: ± 4 diopters.
- Microphone - Stereo.
- Speaker - Monaural.
- Recording media - Internal memory (approx. 87 MB).
- Memory cards - SD, SDHC, SDXC.
- Recording file format
- Still pictures - RAW/JPEG (based on Exif 2.3 standard)/DPOF compatible/MPO.
- Motion pictures (with audio) - AVCHD with Dolby® Digital (2ch)/MP4 with AAC (2ch).
- Operating temperature /humidity - 0°–40°C - 32°–104°F / 10–80 % rh.
- Digital interface - USB 2.0 (High Speed).
- With camera models 18 484 /-488: Data from the PC cannot be written to the camera using the USB cable.
- Analog interface - (video/audio)
- With camera models 18 484 /-487 /-488 /-491 - NTSC/PAL Composite (switched by menu),
- With camera models 18 485 /-486 /-489 /-490 - NTSC Composite, Audio line socket (monaural).
- Terminals HDMI - For HDMI micro cable (type D).
- AV OUT/DIGITAL - Dedicated jack (8 pin).
- Wi-Fi Compliance standard - IEEE 802.11b/g/n (standard wireless LAN protocol).
- Used frequency range - 241–2462 MHz (1–11 ch).
- Encryption method - Wi-Fi compatible WPA™/WPA2™.
- Access method - Infrastructure mode.
- NFC Compliance standard - ISO/IEC 18092 NFC-F (passive mode).
- Battery - (lithium-ion) BP-DC14 E/U.
- Voltage/capacity - 3.7 V /950m Ah.
- Battery charger - ACA-DC11-A/B/C/E/U/K.
- Input - AC 110–240 V 50/60 Hz, 0.2 A.
- Output - DC 5 V 800 mA.
- Dimensions (W x H x D) - Approx. 103 x 63 x 28 mm / 4.06 x 2.48 x 1.10 in (lens retracted).
- Weight Approx. - 173 /195 g - 6.1 /6.9 oz (without /with card and battery).
- Scope of delivery - Camera body, battery charger /AC adapter (Leica ACA-DC11), rechargeable battery (Leica BP-DC14), wrist strap, AV cable, USB cable, CD with long instructions (PDF) , short instructions, Guarantee Card .
- Software Adobe® Photoshop® Lightroom® 5.
- Manufacturer's data as of September 2013
