Summicron (II) f= 5 cm 1:2
- Leica Order Nos. - 11817-black - 11819-black - [1117-black, 1118-chrom, 11318 (DR), 11918 (DR) concurrent in catalog] LLC - 120
- Production era - 1968-1979 < 44,029 lenses
- Variants - Cylindrical aluminum (shown) - KE-7A Elcan version - [Scalloped focusing knurl (SFK) and dual range (DR) close focus (with "eyes") plated brass versions were still available during the decade per Forum discussions 3 & 4 below]
- Lens mount - M-bayonet
- Number of lenses /groups - 6 /5 (aluminum) - [a limited number of the earlier 7 /4 plated brass versions 1117, 1118, 11318 (DR) and 11918 (DR) occur in the serial nos. listed below]
- F stop range - f /2 - f /16
- Closest focusing distance - 0.7 m
- Filter type - E39
- Accessories - Hood: ITDOO 12585
- Dimensions (length x diameter) - 50 x 51 mm / 1.97 x 2.01 in
- Weight - 240 g
- Inscriptions - LEITZ WETZLAR 2XXXXXX SUMMICRON 1:2/50
- ELCAN f/2 50 MM 276-00XX (for the KE-7A 1972-1974 ca.500 lenses)
- Designer - Walter Mandler
- On the street - $US 850 in 2010
Summicron (II) f= 5 cm 1:2 Serial Numbers
Serial numbers compiled from Puts Pocket Pod.* Lens 2822922 is Summicron-R 2/50
| 2269251 | 2270250 | Summicron f= 5 cm 1:2 (SKF-black) | 1968 | 1000 |
| 2278751 | 2279750 | Summicron f= 5 cm 1:2 (SKF-chrom+DR) | 1968 | 1000 |
| 2294001 | 2296350 | Summicron f= 5 cm 1:2 (black) | 1968 | 2350 |
| 2307151 | 2307450 | Summicron f= 5 cm 1:2 | 1968 | 300 |
| 2314751 | 2314800 | Summicron f= 5 cm 1:2 | 1969 | 50 |
| 2330801 | 2332800 | Summicron f= 5 cm 1:2 (black) | 1969 | 2000 |
| 2338801 | 2340800 | Summicron f= 5 cm 1:2 | 1969 | 2000 |
| 2349301 | 2351300 | Summicron f= 5 cm 1:2 | 1969 | 2000 |
| 2356301 | 2358300 | Summicron f= 5 cm 1:2 (SFK-DR-chrom) | 1969 | 2000 |
| 2385701 | 2387700 | Summicron f= 5 cm 1:2 (black 11 817+819) | 1970 | 2000 |
| 2407001 | 2409000 | Summicron f= 5 cm 1:2 (black 11 817) | 1970 | 2000 |
| 2432751 | 2434750 | Summicron f= 5 cm 1:2 (black) | 1970 | 2000 |
| 2438001 | 2440000 | Summicron f= 5 cm 1:2 (black) | 1970 | 2000 |
| 2444001 | 2446000 | Summicron f= 5 cm 1:2 | 1970 | 2000 |
| 2453501 | 2455500 | Summicron f= 5 cm 1:2 (black 11 817) | 1970 | 2000 |
| 2518101 | 2520100 | Summicron f= 5 cm 1:2 (black 11 817) | 1972 | 2000 |
| 2522401 | 2522500 | Summicron f= 5 cm 1:2 | 1972 | 100 |
| 2533851 | 2536250 | Summicron f= 5 cm 1:2 (black 11 817) | 1972 | 2400 |
| 2583501 | 2585500 | Summicron f= 5 cm 1:2 (black 11 819) | 1973 | 2000 |
| 2608501 | 2610500 | Summicron f= 5 cm 1:2 (black 11 817) | 1973 | 2000 |
| 2656901 | 2656950 | Summicron f= 5 cm 1:2 | 1973 | 50 |
| 2698501 | 2698600 | Summicron f= 5 cm 1:2 | 1974 | 100 |
| 2731922 | 2731950 | Summicron f= 5 cm 1:2 | 1975 | 29 |
| 2756351 | 2757350 | Summicron f= 5 cm 1:2 (black) | 1975 | 1000 |
| -276-0164 | 276-0450- | Summicron f= 5 cm 1:2 (ELCAN) | 1972-1974 | ca.500 |
| 2794651 | 2796150 | Summicron f= 5 cm 1:2 | 1976 | 1500 |
| 2822351 | *2826350 | Summicron-M f= 5 cm 1:2 | 1977 | 4000 |
| 2887001 | 2887150 | Summicron f= 5 cm 1:2 | 1978 | 150 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1968-1978 | 40,529 |
Lens superseded by 50mm f/2 Summicron-M
