Traveller Tripod
- Production era - 2013-current
- Type - Light-weight, carbon fiber tripod
- Traveller Tripod
- Code no. - 14101
- Manufacturer's description - design: the three tripod legs ensure stable placement in any situation and offer simple and flexible usage. Eight layers of top-quality carbon fibers guarantee maximum stability, and with a weight of merely 1.2 kg, the Leica Traveller Tripod is as light as a feather. . . When collapsed, it's especially small and handy. A 1/4" to 3/8" screw adapter is included.
- Material - Eight layers of carbon fiber
- Number of leg segments - three, with removable center column
- Extended height - 151 cm
- Max. Height w/o center column - 121 cm
- Min. Height - 10 cm
- Packing dimension - 52 cm
- Weight - 1.2 kg
- Maximum load-bearing capacity - 10 kg
- Ball Heads 24 & 38
- Camera connection - 1 /4 inches
- Bottom thread - 3 /8 inches
- Ball Head 24 code no. - 14113
- Ball diameter - 24 mm
- Dimensions (diameter and height) - 35 x 81 mm
- Weight - 227 g
- Max. Load - 12 kg
- Ball Head 38 code no. - 14114
- Ball diameter - 38 mm
- Dimensions (diameter and height) - 50 x 90 mm
- Weight - 436 g
- Max. Load - 24 kg
- 3x set exchangeable mounting plates for Ball Head 24 & 38
- Code no. - 14115
- Cordura bag for Traveller Tripod
- Code no. - 14116
