Traveller Tripod
Revision as of 20:53, 17 October 2013 by Tdavis (talk | contribs)
  • Production era - 2013-current
  • Type - Light-weight, carbon fiber tripod
  • Traveller Tripod
    • Code no. - 14101
    • Manufacturer's description - design: the three tripod legs ensure stable placement in any situation and offer simple and flexible usage. Eight layers of top-quality carbon fibers guarantee maximum stability, and with a weight of merely 1.2 kg, the Leica Traveller Tripod is as light as a feather. . . When collapsed, it's especially small and handy. A 1/4" to 3/8" screw adapter is included.
    • Material - Eight layers of carbon fiber
    • Number of leg segments - three, with removable center column
    • Extended height - 151 cm
    • Max. Height w/o center column - 121 cm
    • Min. Height - 10 cm
    • Packing dimension - 52 cm
    • Weight - 1.2 kg
    • Maximum load-bearing capacity - 10 kg
  • Ball Heads 24 & 38
  • Camera connection - 1 /4 inches
  • Bottom thread - 3 /8 inches
  • Ball Head 24 code no. - 14113
    • Ball diameter - 24 mm
    • Dimensions (diameter and height) - 35 x 81 mm
    • Weight - 227 g
    • Max. Load - 12 kg
  • Ball Head 38 code no. - 14114
    • Ball diameter - 38 mm
    • Dimensions (diameter and height) - 50 x 90 mm
    • Weight - 436 g
    • Max. Load - 24 kg
  • 3x set exchangeable mounting plates for Ball Head 24 & 38
    • Code no. - 14115
  • Cordura bag for Traveller Tripod
    • Code no. - 14116
