Traveller Tripod
- Production era - 2013-current
- Type - Light-weight, carbon fiber tripod with aluminum fittings manufactured in Germany
- TRAVELER TRIPOD
- Code no. - 14101* - ($US 525 at Oct 2013 announcement)
- Manufacturer's description - design: the three tripod legs ensure stable placement in any situation and offer simple and flexible usage. Eight layers of top-quality carbon fibers guarantee maximum stability, and with a weight of merely 1.2 kg, the Leica Traveller [[[sic]]] Tripod is as light as a feather. . . When collapsed, it's especially small and handy. A 1/4" to 3/8" screw adapter is included.
- Material - Eight layers of carbon fiber
- Number of leg segments - three, with removable center column
- Extended height - 151 cm ~ 5 ft
- Max. Height w/o center column - 121 cm ~ 4 ft
- Min. Height - 10 cm ~ 4 in
- Packing dimension - 52 cm ~ 20.5 in
- Weight - 1.2 kg - 2.65 lbs
- Maximum load-bearing capacity - 10 kg - 22.08 lbs
- BALL HEAD 24
- Code no. - 14113 - ($US 285 at Oct 2013 announcement)
- Ball diameter - 24 mm - 0.94 in
- Dimensions diameter x height - 35 x 81 mm
- Weight - 227 g - 0.5 lbs
- Maximum load-bearing capacity - 12 kg - 26.46 lbs
- Camera connection - 1 /4 in
- Bottom thread - 3 /8 in
- BALL HEAD 38
- Code no. - 14114 - ($US 390 at Oct 2013 announcement)
- Ball diameter - 38 mm - 1.5 in
- Dimensions diameter x height - 50 x 90 mm
- Weight - 436 g - 52.92 lbs
- Maximum load-bearing capacity - 24 kg - 52.92 lbs
- 3x set exchangeable MOUNTING PLATES for heads 24 & 38
- Code no. - 14115 - ($US 55 at Oct 2013 announcement)
- CORDURA BAG FOR TRAVELER TRIPOD SET
- Code no. - 14116 - ($US 100 at Oct 2013 announcement)
.* Note: 14101 was also used as the 1949 code for Leitz NY Tiltall Tripod, per Laney.
