NEC
- Panel Technology - IPS
- Viewable Image Size - 29.8 in
- Aspect Ratio - 16:10
- Native Resolution - 2560 x 1600
- Pixel Pitch - 0.25mm
- Pixels Per Inch - 101@ native resolution
- Backlight Type - GB-R LED
- PWM Frequency - 49 KHz
- Brightness (typical) - 340cd /m2
- Contrast Ratio (typical) - 1000 : 1
- Viewing Angle (typical) - 178° Vert., 178° Hor. (89U/89D/89L/89R) @ CR>10
- ResponseTime (typical) - 6 ms
- Color Gamut
- Adobe RGB Coverage /Size - 99.3% / 108.6%
- NTSC Coverage /Size - 94.8% / 103.7%
- sRGB Coverage /Size - 146.4% / 100%
- Lookup Table - 14-bit (3D)
- Displayable Colors - 1.07 billion out of 4.3 trillion
- Synchronization Range
- Horizontal (Analog /Digital) - 31.5-98.7 kHz (Digital only)
- Vertical - 50 - 85 Hz
- Input Connectors - DisplayPort, Mini DisplayPort, HDMI, DVI-D Dual Link, USB hub (2 up/ 3 down) with DisplaySync Pro
- Power Consumption (typical)
- On - 87 W
- Power Savings Mode - 1.4 W
- Physical Specifications
- Dimensions (WxHxD)
- Net (with stand) - 27.1 x 18.4-24.3 x 11.9 in. / 688.3 x 466.4-616.4 x 301.6mm
- Net (without stand) - 27.1 x 17.6 x 3.2 in. / 688.0 x 446.8 x 82.0mm
- Weight
- Net Weight (with stand) - 37.5 lbs. / 17.0 kg
- Net Weight (without stand) - 23.6 lbs / 10.7 kg
- VESA Hole Configuration Specifications - 100 x 100mm, 200 x 100mm
- Environmental Conditions
- Operating Temperature - 41-95°F / 5-35°C
- Operating Humidity - 20-80%
- Operating Altitude - 16,404 ft. / 5000m
- Storage Temperature - 14-140°F / -10-60°C
- Storage Humidity - 10-85%
- Storage Altitude - 40,000 ft / 12,192 m
- Environmental Compliance
- RoHS - Yes
- Limited Warranty (parts & labor, including backlight) - 4 years
- Additional Features - ECO Mode, Carbon footprint meter, Thin frame, Tilt, Swivel, Pivot, Height-adjustable stand with locking base, Quick release stand, Carrying handle, Rapid Response, Ambix4, XtraView+, OSD user controls, MultiProfiler software, USB hub (2 up/3 down) with DisplaySync Pro, Cable management, Touch-integratable, VESA mount, HDCP, DDC/CI, 14-bit 3D LUT, Digital Uniformity Correction, Black Level adjustment, AmbiBright, Wide Color Gamut, Adobe RGB, CableComp, TileMatrix, TileComp, GammaComp MD QA software, SpectraView software-ready, Standalone hardware calibration
- Ships With
- Power cable
- DisplayPort cable
- Mini DisplayPort to DisplayPort cable
- DVI cable
- USB cable
- Mounting Screws
- Optional Accessories
- SpectraViewII Color Calibration Kit - SVII-PRO-KIT
- Color calibration sensor - MDSVSENSOR3
- SpectraView software - SVIISOFT
- Hood - HDPA30-2
- Manufacturer's tech specs as of 10 Jan 2014
