DELL
Revision as of 14:50, 11 January 2014 by Tdavis (talk | contribs) (Created page with "400px *'''Model''' - UltraSharp 30 PremierColor Monitor - U3014 *'''DISPLAY''' **'''Diagonal Viewable Image Size''' - 75.6 cm /29.8 in (30-inch wide ) **'''...")
  • Model - UltraSharp 30 PremierColor Monitor - U3014
  • DISPLAY
    • Diagonal Viewable Image Size - 75.6 cm /29.8 in (30-inch wide )
    • Aspect Ratio - 16 : 10
    • Panel Type, Surface - AH In-plane switching, anti glare with hard coat 3H
    • Optimal resolution - 2560 x 1600 at 60 Hz
    • Contrast Ratio - 1000 to 1 (typical)
    • Dynamic Contrast Ratio - 2 Million : 1 (Max)
    • Brightness - 350 cd /m2 (typical), 50 cd /m2 (minimum)
    • Response Time - 6 ms (gray to gray)
    • Viewing Angle - (178° vertical /178° horizontal)
  • Color Support
    • Color Gamut (typical) - Adobe RGB 99%, sRGB 100% and 120% (CIE 1976)
    • Color Depth - 1.07 billion colors
    • Pixel Pitch - 0.25 mm
    • Backlight Technology - LED
    • Display Type - Widescreen Flat Panel Display
  • CONNECTIVITY
1 Dual Link Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort 1.2 (DP)
1 Mini DisplayPort 1.2 (mDP)
1 High Definition Multimedia Interface (HDMI)
1 USB 3.0 upstream port
4 USB 3.0 downstream ports
1 DisplayPort out (MST)
1 Audio out
DC power connector for Dell Soundbar (AX510)
  • ADJUSTABILITY - Height adjustable stand, tilt , swivel and built in cable-management, capacitive touch OSD controls
    • Flat Panel Mount Interface - VESA
  • BUILT-IN DEVICES
USB 3.0 Hi-Speed Hub (with 1 USB upstream port and 4 USB downstream ports)
DC-out
  • SECURITY
Security lock slot (security lock sold separately)
Anti-theft stand lock slot (to panel)
  • SIZE AND WEIGHT
    • Dimensions with stand (H x W x D) - 19.00 ~ 22.55 in (482.7 ~ 572.7 mm) x 27.15 in (689.7 mm) x 7.93 in (201.4 mm)
    • Dimensions without stand (H x W x D) - 17.69 in (449.2 mm) x 27.15 in (689.7 mm) x 2.40 in (61.0 mm)
    • Viewable Image Dimension (H x W) - 641.3 x 400.8 mm /25.25 x 15.76 in
    • Weight (panel only - for VESA mount) - 10.84 kg (23.89 lb)
    • Weight (with packaging) - 13.65 kg (30.09 lb)
  • Service / Support Details - 3-Year Advanced Exchange Service and Premium Panel Guarantee
  • Electrical and Regulatory
    • Voltage Required - 100 to 240 VAC / 50 or 60 Hz + 3Hz / 1.8 A (typical)
    • Power Consumption (Operational) - 60W (typical) / 120W (maximum)10
    • Power Consumption Stand by / Sleep - Less than 0.5 W
  • ENVIRONMENTAL
    • Temperature Range Operating - 0° to 40°C (32° to 104°F)
    • Temperature Range Non-operating
      • Storage - -20° to 60° (-4° to 140° F)
      • Shipping - -20° to 60° (-4° to 140° F)
    • Humidity Range Operating - 10% to 80% (non-condensing)
    • Humidity Range Non-operating
      • Storage - 5% to 90% (non-condensing)
      • Shipping - 5% to 90% (non-condensing)
    • Altitude Operating - 5000 m (16,500 ft) max
    • Altitude Non-operating - 10,668 m (35,000 ft) max
  • COMPLIANCE AND STANDARDS
Energy Star
EPEAT Gold
TCO Certified Displays
Product Safety, EMC and Environmental Datasheets
Dell Regulatory Compliance Home Page, Dell and the Environment, Dell Pixel Policy
  • WHAT'S IN THE BOX
Monitor with stand (Monitor includes Dell UltraSharp Color Calibration Solution)
Power Cable
DVI-D Cable (Dual Link)
DisplayPort Cable (Mini DP to DP)
USB3.0 upstream Cable
Cable Tie
Drivers and Documentation media
Factory Color Calibration Report
Quick Setup Guide
Safety Information
  • WARRANTY - 3 Years Advanced Exchange Service & Limited Hardware Warranty, Premium Panel Guarantee
