90 mm f/4 Macro-Elmar-M
Revision as of 20:42, 3 July 2014 by Tdavis (talk | contribs)
  • Leica Order No. - 11 6??-black (changes from 2004 verion in red)
  • Production era - 2014-Current
  • Variants - Black
  • Lens mount - Leica M quick-change bayonet
  • Compatibility - Unlike other collapsible lenses, 90mm f/4 Macro-Elmar-M can be used on M8 or M9 cameras without restriction, as the extension tube does not extend into the camera.
  • Number of lenses/groups - 4 /4
  • Focusing range - 0.77 m / 2.5 ft < ∞ (with Leica MACRO-ADAPTER-M: 0.5 < 0.76 m / 1.6 < 2.5 ft)
  • Aperture - f/4-f/22 - with click-stops, half values available
  • Diaphragm setting /type - 10-blade
  • Smallest object field/Largest reproduction ratio - 169 mm x 244 mm (with LEICA MACRO-ADAPTER-M: 72 x 108 mm)/1:6.7 (with LEICA MACRO-ADAPTER-M: 1:3)
  • Angle of view (diagonal, horizontal, vertical) - 27°, 23°, 15° - (M8 20°, 17°, 11°)
  • Position of entrance pupil - 22 mm / 0.67 in (related to the first lens surface in light direction)
  • Filter mount - Non-rotating, internal thread for screw-on filters size E39
  • Accessories - Hood: IUFOO, can be attached in reverse for storage and also 12575 - MACRO-ADAPTER-M 14 409 - ANGLEFINDER-M - Leica M Viewfinder Magnifiers 1.25x & 1.4x, Cap: 14285 black chrome
  • Viewfinder - Camera viewfinder
  • Materials - Anodized aluminum and optical glass
  • Focal length - 90.0 mm / 3.54 in
  • Length to bayonet flange - 41 < 59 mm / 1.61 < 2.32 in
  • Largest diameter - 52 mm / 2.05 in
  • Weight - 230 g - 8.11 oz black anodized aluminum
  • Inscription - LEICA MACRO-ELMAR-M 1:4/90 E39 419XXXX
  • Manufacturer's technical data
90 mm f/4 Macro-Elmar-M Serial Numbers
Serial numbers compiled from known 90 mm f/4 Macro-Elmar-M
-419710 unknown- 90 mm f/4 Macro-Elmar-M (black) 2014 unknown
TOTAL ASSIGNED SERIAL NUMBERS 2014- unknown
