Vario-Elmar-S 30-90mm f/3.5-5.6 ASPH.
Revision as of 16:35, 27 September 2014 by Tdavis (talk | contribs) (→Leica Vario-Elmar-S 30-90mm f/3.5-5.6 ASPH. Serial Numbers)
- Order number - 11058
- Production era - 2012-
- Optical design
- Lenses /groups - 14 /11
- Image angle (diagonal, horizontal, vertical) - WA 81.5°, 71°, 51°, /T 34°, 28.5°, 19.5°, corresponds to approx. WA 24 mm /T 72 mm focal length in 35 mm format
- Position of entrance pupil - WA 72.8 mm /T 65.9 mm from apex of 1st lens element
- Setting /function - Electronically controlled diaphragm, set using dial on camera, including half values
- Aperture range - 3.5 to 32
- Focusing range - 0.65 m to infinity
- Distance setting
- Smallest object field - 514 mm × 771 mm at 30 mm /194 mm × 291 mm at 90 mm
- Largest reproduction ratio - 1 : 6.5
- Size
- Filter mount - Internal thread for E95 filter, filter mount does not rotate
- Dimensions (diameter /length) - 101 mm /113.5 mm
- Weight: 1275 g
- Accessories included - Lens Hood : 12404 - Rear lens cover : 16020 - Lens cover S 16027
- Leica Tech Data - Vario_Elmar-S_en.pdf
Serial numbers compiled from known Vario-Elmar-S 30-90mm f/3.5-5.6 ASPH. lenses~ stolen lens, please report if found on sale
| -4146451 | unknown- | Vario-Elmar-S 30-90mm f/3.5-5.6 ASPH. | 2012 | unknown |
| -unknown | 4183223~ | Vario-Elmar-S 30-90mm f/3.5-5.6 ASPH. | 2013 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2012-Current | unknown |
