Digilux 2
3D image Click-to-turn view
Code numbers - 18255 EU, 18256 F/NL, 18257 SP/IT, 18258 UR/HK, 18259 AU
Focus range - Close-up limit 30 cm (ca. 12 inches) and 15 cm with ELPRO-D E69.
Accessories - Black leather case 18627, Li-ion Battery, UVa Filter, 4x ND Filter, Filter Holder, SF 24D Flash Unit, and the ELPRO-D E69 to extend focusing limits in the close-focus range 18633 - Electronic Cable Release: 18626 CR-DC1 - Manual Cable Release: 14076
Specifications - adapted from manufacturer's technical data of June 2006. Leica Digilux 2 Data
Manuals & brochures
- Instructions.pdf (in English starts at page 99)
- Digilux 2 Brochure.pdf
Forum discussion
- Digilux 2 User Group
- [1]
- [2]
- [3]
- [4]
- [5]
- [6]
- [7]
- [8]
- [9]
- [10] [11][12][13]
- Sensor failure (long thread)
- [14] [15]
- [16]
- [17]
- [18]
- [19]
- [20] [21] [22]
- [23]
- [24] [25] [26]
- [27]
- [28]
- [29] [30] [31] [32]
- long "distinctive" thread
- [33]
- [34] [35]
Reviews
- Thorsten Overgaard [36] [37]
- Andy Piper
- Digilux 2 Wikipedia
- Luminous Landscape [38] [39] [40]
- Philip Dygeus | Digilux 2 RAW ISO Comparison
Digilux 2 Serial Numbers
Serial numbers compiled from Puts Pocket Pod^ Camera 2999690 is Digilux 2
~ Camera 2998788 is stolen Digilux 2, please report if found on sale
| 2984401 | 2999400 | Digilux 2 | 2003 | 15,000 |
| 2999401 ^ | 2999997 ~ | MP ^ | 2003 | [597] |
| 3004001 | 3005000 | Digilux 2 | 2004 | 1,000 |
| 3011101 | 3026100 | Digilux 2 | 2004 | 15,000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2003-2004 | 31,000 |
