APO-Elmar-S 180mm f/3.5
Revision as of 15:21, 1 October 2014 by Tdavis (talk | contribs)
  • Order numbers - 11071 - 11053 (CS version with Central Shutter)
  • Production era - 2009- (CS Oct 2012)
  • Lenses /groups - 9 /7
  • Optical design - Internal focusing
  • Image angle (diagonal, horizontal, vertical) - approx. 17°, 14°, 9.5°, approx. corresponds to 144 mm in 35 mm-format
  • Aperture range - 3.5 to 22
  • Shortest distance - 1.5 m - (1.1 m w/ Close-Up Converter Lens 16032)
  • Largest image scale - 1:7 - (1.45 w/ Close-Up Converter Lens 16032)
  • Filter thread size - 72 mm
  • Dimensions (diameter/length) - 88 mm/151 mm
  • Weight: 1150 g (CS: 1300 g )
  • Accessories included - Lens Hood : 12403 - Rear lens cover : 16020 - Lens cover S : 16018
  • Accessories optional - 16032 - Elpro-S 180 mm (introduced November 2012) reduces the minimum focus distance of the 180mm lens to 3.6' (1.1 m) and increases the maximum reproduction ratio of the lens from 1:7 to 1:4.5.
  • Serial nos. -4090070-4090870-4090930-4090966-
  • Leica Tech Data - APO-Elmar-S 180mm f/3.5.pdf - courtesy Summilux.net
  • Forum discussion
