F = 12.5 cm 1:2.5 Hektor
- Leica Order No. - HIKOO . LLC - 181
- Production era - 1954-1963 < 4,400 (one source has 3308) lenses
- Variants - 11532 scale in meters, 11032 scale in feet; Wetzlar and ELC versions
- Lens mount - Visoflex
- F stop range - f/2.5 - f/22
- Closest focusing distance - 1.2 m /3.94 ft
- Smallest object field -
- Diaphragm setting /type - 20-blade
- Angle of view diagonal - 20 degrees
- Filter type -
- Accessories - Hood: HKMOO
- Weight - 660 g /1.46 lb
- Inscription - Hektor f=12.5cm 1/2.5 Nr. 1XXXXXX Ernst Leitz GmbH Wetzlar
- History - This lens has a interesting history and came close to never existing as a viso lens. Walther Benser gave lectures on Leica cameras with projection of slides before WWII. He used this lens on his projector. Then he was inducted into the German army, ended up as a photographer and was deep in the Caucasus when the Russians won the battle of Stalingrad. This meant that the Caucasus had to be evacuated by the German army. Walther was almost captured but made it out to Rostov. If captured this lens would never exist because he convinced Ernest Leitz II to make the lens for the Visoflex system. DannyBell
- On the street - €EU 240 in 2009
Leica F = 12.5 cm 1:2.5 Hektor Serial Numbers
Serial numbers compiled from known lenses and Puts Pocket Pod.pdfNote: Westlicht Lot 86/07 has 1223282 out of range (assigned to Focotar)
* Lens 1224189 is 12.5 cm 1:2.5 Hektor (ELW)
| 753001 | 753100 | [12]+12.5 cm 1:2.5 Hektor (ELW) | 1949 | 100 |
| 1051001 | 1052000 | 12.5 cm 1:2.5 Hektor (ELW) | 1953 | 1000 |
| 1121001 | 1121500 | 12.5 cm 1:2.5 Hektor (ELW) | 1953 | 500 |
| 1214001 | 1214500 | 12.5 cm 1:2.5 Hektor (ELC) | 1954 | 500 |
| 1223001 | 1223200 | 12.5 cm 1:2.5 Hektor (ELC) | 1954 | 200 |
| 1224001* | 1224200 | *9 cm 1:4 Elmar | 1954 | [200] |
| 1305001 | 1305500 | 12.5 cm 1:2.5 Hektor (ELW) | 1955 | 500 |
| 1650001 | 1651000 | 12.5 cm 1:2.5 Hektor (ELW+ELC) | 1959 | 1000 |
| 1760001 | 1760600 | 12.5 cm 1:2.5 Hektor (ELW+ELC) | 1960 | 600 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1949-1960 | 4,400 |
