135mm f/2.8 Elmarit-R II
Revision as of 14:05, 13 October 2014 by Tdavis (talk | contribs)
  • Leica Order No. - 11211 . LLC - 184
  • Production era - 1968-1998 < 50,800 lenses
  • Variants - ROM conversion versions
  • Number of lenses /groups - 5 / 4
  • F stop range - f/2.8 - f/22
  • Closest focusing distance - 1.5 m / 4.92 ft
  • Smallest object field - 220 x 330 mm
  • Diaphragm setting /type -
  • Angle of view diagonal - 18 degrees
  • Filter type - E55
  • Accessories - ELPRO close focusing attachment type 4; Cap 14289, 14089 or 14809.
  • Materials -
  • Dimensions length x diameter - 93 x 67 mm /3.66 x 2.6 in
  • Weight - 730 g /1.23 lb
  • Inscriptions - ELMARIT-R 1:2.8/135 LEITZ CANADA 2XXXXXX
    ELMARIT-R 1:2.8/135 LEITZ WETZLAR 2XXXXXX
    ELMARIT-R 1:2.8/135 E 55 3XXXXXX LEICA
  • Designer - Walter Mandler
  • On the street - €EU 504 in 2007 - $US 250 in 2010
  • Forum discussion
135mm f/2.8 Elmarit-R II Serial Numbers
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf
* Lens 3104870 & 3178214 are 135mm f/2.8 Elmarit-M
^ Lens 2982747 & 2988534 are 135mm f/2.8 Elmarit-R
2296351 2298350 135mm f/2.8 Elmarit-R (ELW) 1968 2000
2305151 2307150 135mm f/2.8 Elmarit-R 1968 2000
2362001 2364000 135mm f/2.8 Elmarit-R 1969 2000
2376901 2378900 135mm f/2.8 Elmarit-R (ELW) 1969 2000
2398401 2400000 135mm f/2.8 Elmarit-R 1970 1600
2404001 2406000 135mm f/2.8 Elmarit-R 1970 2000
2466501 2468500 135mm f/2.8 Elmarit-R 1970 2000
2529601 2531600 135mm f/2.8 Elmarit-R (ELC) 1972 2000
2610501 2613000 135mm f/2.8 Elmarit-R 1973 2500
2621101 2622100 135mm f/2.8 Elmarit-R 1973 1000
2663451 2665450 135mm f/2.8 Elmarit-R 1974 2000
2729421 2731420 135mm f/2.8 Elmarit-R (ELC) 1974 2000
2775851 2776350 135mm f/2.8 Elmarit-R 1976 500
2796151 2798150 135mm f/2.8 Elmarit-R (3-cam.ELC) 1976 2000
2809401 2811400 135mm f/2.8 Elmarit-R 1977 2000
2843051 2845050 135mm f/2.8 Elmarit-R 1977 2000
2886401 2887000 135mm f/2.8 Elmarit-R 1978 600
2963501 2967000 135mm f/2.8 Elmarit-R 1978 3500
2982601 ^ 2983100 21mm f/4 Super-Angulon ^ 1979 [500]
2988101 ^ 2989100 90mm f/2.8 Elmarit-R ^ 1979 [1000]
3027801 3029800 135mm f/2.8 Elmarit-R (3-cam) 1980 2000
3045101 3046600 135mm f/2.8 Elmarit-R 1980 1500
3104001 * 3105000 135mm f/2.8* Elmarit-R 1981 1000
3105501 3107500 135mm f/2.8 Elmarit-R (ELC) 1981 2000
3135001 3136800 135mm f/2.8 Elmarit-R 1981 1800
3146501 3148500 135mm f/2.8 Elmarit-R 1981 2000
3178201* 3179200 135mm f/2.8 Elmarit-R 1982 1000
3341201 3342200 135mm f/2.8 Elmarit-R 1984 1000
3375501 3376000 135mm f/2.8 Elmarit-R 1985 500
3380501 3381000 135mm f/2.8 Elmarit-R 1985 500
3397601 3398100 135mm f/2.8 Elmarit-R 1986 500
3405701 3406200 135mm f/2.8 Elmarit-R 1986 500
3435001 3435500 135mm f/2.8 Elmarit-R 1987 500
3457371 3457870 135mm f/2.8 Elmarit-R 1988 500
3487251 3487550 135mm f/2.8 Elmarit-R 1989 300
3507151 3507450 135mm f/2.8 Elmarit-R 1990 300
3524296 3524795 135mm f/2.8 Elmarit-R 1990 500
3562168 3562467 135mm f/2.8 Elmarit-R 1991 300
3580019 3580418 135mm f/2.8 Elmarit-R (ELC) 1991 400
TOTAL ASSIGNED SERIAL NUMBERS 1969-1991 50,800
