135mm f/2.8 Elmarit-R I
Revision as of 14:16, 13 October 2014 by Tdavis (talk | contribs)
  • Order no. - 11111 . LLC - 184
  • Production era - 1964-1968 < 16,250 lenses
  • Variants - 1-cam, 2-cam and 3-cam versions
  • Number of lenses /groups - 5 / 4
  • F stop range - f/2.8 - f/22
  • Closest focusing distance - 1.5 m / 4.92 ft
  • Smallest object field - 220 x 330 mm
  • Diaphragm setting /type - 8-blade
  • Angle of view diagonal - 18 degrees
  • Filter type - Series VII
  • Accessories - ELPRO close focusing attachment
  • Materials -
  • Dimensions length x diameter - 91 x 65 mm / 3.58 x 2.56 in
  • Weight - 655 g /1.44 lb
  • Inscription - ELMARIT-R 1:2.8/135 LEITZ CANADA 2XXXXXX
  • Designer - Walter Mandler
  • On the street - $US 150 in 2010
  • Forum discussion
135mm f/2.8 Elmarit-R I Serial Numbers
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf
1967001 1967100 135mm f/2.8 Elmarit-R 1962 100
1995501 1995900 135mm f/2.8 Elmarit-R 1963 400
1995901 1996000 135mm f/2.8 Elmarit-R 1963 100
2018001 2020000 135mm f/2.8 Elmarit-R (2-cam) 1964 2000
2040701 2041700 135mm f/2.8 Elmarit-R 1964 1000
2051001 2052000 135mm f/2.8 Elmarit-R 1964 1000
2093501 2094500 135mm f/2.8 Elmarit-R 1965 1000
2131951 2132950 135mm f/2.8 Elmarit-R 1965 1000
2136951 2139950 135mm f/2.8 Elmarit-R (1-cam) 1965 3000
2154901 2155550 135mm f/2.8 Elmarit-R 1965 650
2171701 2173700 135mm f/2.8 Elmarit-R 1966 2000
2192901 2194900 135mm f/2.8 Elmarit-R 1966 2000
2244051 2246050 135mm f/2.8 Elmarit-R 1967 2000
TOTAL ASSIGNED SERIAL NUMBERS 1962-1968 16,250
Lens superseded by 135mm f/2.8 Elmarit-R II
